random missfire help please
Old Mar 28, 2011 | 06:34 PM
Blue1990camaro's Avatar
ok so idle and driving runs fine, in park or nuetral if u idle it up or hold it at higher then idle u can hear it will miss every couple seconds, not sure why, all new plugs wires filters the whoel 9 yards, its a 90 3.1 mpfi 150k miles
Old Mar 29, 2011 | 04:32 PM
Re: random missfire help please
anyone??
Old Mar 30, 2011 | 08:52 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
One of the fuel injectors could be partially clogged... Only way to test would be a balance test.
Old Mar 30, 2011 | 04:18 PM
they r all new injectors, all 6 only have mayb 2k miles on them if that.
Old Mar 30, 2011 | 04:38 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Just because they're relatively new doesn't mean there is nothing wrong with them. Any random part can fail at any random time in any random manner. Even with only 6K on them, the fuel injectors could still get clogged inlet filter baskets or some debris inside or on the intake end.
Old Mar 30, 2011 | 05:02 PM
what would u sugest i shuld do? i cant aford new injectors right now, i already did full tune up all new plugs wires filters and everything,
and a 3.4 is going in as well but im going to be reusing all my harness and sensors plugs wires distributor and everything but using the 3.4 injectors, so im worried when i go to fire up the 3.4 itl run just as shity, im swaping becuase i need a new trans, and the 3.1 is just worn out
Old Mar 30, 2011 | 05:26 PM
Engine: 2.7L V6
Axle/Gears: 4.41
If it doesn't affect the actual driveability of the car, I'd leave it as it is. Mine had a random misfire I chased my tail on for a long time but it ran great on the street with no problems. If you're going to be dropping in a 3.4 anyways, I'd send those injectors (the 3.4 injectors) out somewhere to have them professionally cleaned before you throw that in to avoid any possible problems. Other than that, if you can afford to have the car down for a couple weeks or so, I'd send the injectors to SouthBay or somewhere to be cleaned and tested. It's not cheap, but it's about half the price of new injectors.
That's if the injectors are the problem. Test the resistance of the plug wires. Any wire with a resistance of more than 10K ohms per foot (no more than 20K for the #1 and 2 wires) needs to be chucked. Pull the plugs and check them for proper gap and fouling and any other possible damage. Other than that, without being there to actually test things, there really isn't much more anyone can say.
Old Mar 30, 2011 | 05:59 PM
damn alrite, ill prolly put new plugs and wires in the 3.4 as well as cap and rotor, any sugestions on brand and types??
Old Mar 30, 2011 | 06:04 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Whatever Delco plugs the 3.4 came from the factory with and ANYTHING but cheapo bottom of the barrel plug wires that the terminals come off of every time you pull them off of the plugs. As for the cap and rotor, try to find a set with brass terminals.
Old Mar 30, 2011 | 06:44 PM
i used BOCH PLATINUM 2 plugs last time, they have the 2 posts on on each side of teh center electrode ya kno? used em in my z24 with the 2.8 got a MAJOR difference...made no diff in the camaro 3.1 tho =(
Old Mar 30, 2011 | 06:53 PM
southbay08's Avatar
Hey Blue1990camaro, if you want to send the injectors to us, we will put them on our bench and check them out for you...no charge.
Old Mar 31, 2011 | 10:12 AM
Engine: 2.7L V6
Axle/Gears: 4.41
I keep wondering why everyone insists on spending twice as much money (and sometimes 4x as much) for those crap plugs... It's been proven that those plugs STILL fire on ONLY ONE ELECTRODE, which makes them NO better than the stock $2 a piece Delco plugs. I had a set of those in my car a long time ago thinking they were better and the engine actually ran WORSE with them in... Which is why I still use the cheap copper Delco R43TSK plugs I've been running since 2005...
Old Mar 31, 2011 | 03:13 PM
this is true, but they did make a difference in my cavy, which is a bored n stroked 2.8 with a mild lift cam, i was hoping they run better but it was a waste in the camaro im buying ac's tomorow
lol if i didnt have to drive teh car daily i would, but could i send you the ones outa my 89 Z24? 2.8L MPFI?
Old Mar 31, 2011 | 03:59 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
When my car was handed down to me there were Bosh platinum 4's and the car ran like complete crap with them in there. I will always use the cheapo delco plugs as they seem to work just fine. We have the delco rapid fires in the "father-son project" S10 blazer and they don't make any difference what so ever over the standard plugs.
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
ndndndnd
Sep 28, 2015 08:00 AM
Jk_Under
Sep 8, 2015 08:13 AM
