Air box?
Old Feb 26, 2001 | 06:14 PM
steven's Avatar
Air box?
on my V6 can i just take the metal air filter holder of and hook my K&N striaght to the plastic pipe. There is a Wire that connects to the holder, does it matter if i disconnect it or is important. haha, thanks for info, later.
191(3.1)V6 1992 Pontiac Firebird,K&N drop in filter, bosch patinum spark plugs, Pioneer reciver, kenwood 4x6's, sony xplod 6x9's, two kenwood tornado 12's with a 300 watt jenson running them, check it out at www.geocities.com/my_92firebird
Old Feb 26, 2001 | 06:18 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
yeah it's important...if you disconnect it your SES light will come on. the sensor is your MAT sensor and it's basically measuring the temp of incoming air. you could always cut a hole in a part of the intake hose and mount it there.
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Old Feb 26, 2001 | 09:10 PM
steven's Avatar
can i do this: http://exit3.i-55.com/~davidlt/air_intake.htm
Old Feb 26, 2001 | 11:49 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
where did they mount all the sensors w/ that setup?
Stock 2.8 MPFI auto w/ Flowmaster 40, More to come......
New Pioneer Head Unit
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Old Feb 27, 2001 | 02:19 AM
RenoLB8's Avatar
It's a MAP engine instead of MAF. Doesn't have a MAF, and I'm pretty sure it's sans IAT/MAT too. So that setup would be REAL easy on that engine. It'd be just about as easy on ours, though, you just need to replace a section of the tubing with your MAF, and then poke a small hole somewhere for the IAT/MAT.
-Reno
'88 Firebird LB8
"Cerberus"
http://www.angelfire.com/il/Firebird28/index.html
Old Feb 27, 2001 | 11:43 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I jus tput a 4.7 ohm resistor were my IAC used to be im thinking of goin up to about 7+ becasue now im running way to rich the lower the resistor the colder your computer thinks it is and the high resistor it will think its hotter outside
Old Feb 27, 2001 | 10:40 PM
steven's Avatar
so just poke a hole in the mtal part of that picture and put that sensor in there?
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Dialed_In
Aug 20, 2015 01:45 PM
bryan623
Aug 10, 2015 11:33 AM
