What size are the valve cover studs?
Old Apr 6, 2011 | 05:43 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I need to replace the studs that the valve cover hold down nuts bolt to. I don't need replacement studs- I need the size so I can use some bolts to connect some plug wire looms to the valve covers...
Old Apr 6, 2011 | 11:18 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: What size are the valve cover studs?
Seriously guys, someone must know what size this stud is...
Old Apr 7, 2011 | 02:13 AM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Plain old sbc's with perimeter bolt valve covers are tapped for 5/16 X 24 hardware.
Old Apr 7, 2011 | 09:56 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Looks like I found something. I have polished Fiero valve covers and the Fiero 2.8 apparently uses M6x1.0x26 bolts, with a sleeve so that the covers do not get distorted... I will let you know how it goes...
db057
Sep 4, 2015 07:57 AM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
