after market temp guage question
Old Mar 9, 2001 | 07:39 PM
HIX5000's Avatar
I got a mechanical water temp guage today and was wondering where I should install the capillary tube tip.
1988 Camaro RS
2.8L five speed
TB bypass
1988 Camaro
2.8L automatic
t-tops
160* THERMO, TB bypass
Rapid fire plugs
Old Mar 9, 2001 | 10:04 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
i had mine installed. After reading the auto meter instructions with drilling into the head etc i didnt wanna screw with it.
" I'd rather run last in a full out race, than to NOT run at all ".
Old Mar 10, 2001 | 02:05 PM
HIX5000's Avatar
Can I just remove the sensor from my stock temp guage and put this one in it's place or will that disable something else?
Old Mar 10, 2001 | 05:59 PM
u can but then ur stock gauge wont work. I wanted everything to work including stock stuff
Old Mar 10, 2001 | 09:27 PM
HIX5000's Avatar
Well my stock guage is broke. Is it the sensor under the throttle body or the one by the distributor?
Old Mar 15, 2001 | 01:12 AM
GOLD85's Avatar
if the temp sensor is fragged wouldnt that make the engine run ruff. i mean the computer has to know what the temp is to adjust fuel mixtur and $hit. or is sensor strickly for the factory gauge.
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
R.I.P #3
Old Mar 15, 2001 | 08:57 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, just remove the factory sender. It should be on the outermost corner of the driver's side head, at the front. That's what I did. I also had to buy an Autometer adapter to convert the smaller fitting on the gauge to the larger hole in the head.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Bstrang6
Sep 8, 2015 04:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
gta power
Aug 13, 2015 06:15 AM
