Priming the oil pump
Old Mar 14, 2001 | 07:58 AM
Kyle F's Avatar
How do you prime the oil pump on a 3.8L with the distibutorless ignition, like on the TTA.
FOR SALE!!!!!!!!!!!!!!!
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added. Soon to have Intrax lowering springs.
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
The Third Gen Will Never be Forgotten
Old Mar 14, 2001 | 08:45 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
This is how it's done for 2.8/3.1 DIS cars, so hopefully GM did the same thing for the 3.8.
The 3.8 will have an "oil pump drive"- it's the lower half of a distributor. It's got the shaft & gear to connect the camshaft to the oil pump's drive shaft. Like a distributor, it also uses a hold-down-bolt to keep it in the engine. So, you'd use a regular engine oiler, or if you didn't want to pressurize the lifters, you could just use a socket & extension to fit the oil pump's hex drive shaft.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 14, 2001 | 03:52 PM
Kyle F's Avatar
I just need ot lubricate the engine, the car hasn't been started for 2 years and the hasn't got more that like 1000 miles on it since 94 so I think I need to get the engines oil pressure up first before I start it.
Old Mar 15, 2001 | 12:12 AM
KED85's Avatar
Tom has it right,
(You are one smart lad )
Pop off the hood, get off the distributor less unit, insert along screwdriver.
Wait, isn't the oil pump in the front of the engine?
Call this guy, I got his number from Hot Rod mag.
He's real good.
Poston 334-368-8577
He deals in Buick GN stuff, like the engine you've got.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Mar 15, 2001 | 06:20 AM
Kyle F's Avatar
Cool thanks, but can you give me more information about what else he does. Does he sale stuff or what?
Old Mar 15, 2001 | 09:30 AM
KED85's Avatar
Hi Kyle,
This guy is very big in the GN circle, similar level as Kenne-Bell.
He has 2 ads in Hot Rod ad section, all year. That does cost money!
He sells all the items you want, buys things, creates HI-Perf parts.
He is a BIG Buick tech head.
You DO have a Buick engine (I saw my first 3.8 back in 1973, in a 1965 Buick Special 2 door post. What is that? I had my 1966 Corvette then, I didn't know everything).
I helped rebuild a 3.8 in a 1980 Firebird. The timing chain cover houses the oil pump, right by the oil filter. The timing chain cover plays major role in oil pressure performance.
May be worth it to just remove that part of the engine, slip on new chain and freshen up the spring pressure.
Check with this guy, tho.
His address is
Poston Ent. 334-368-8577, 206 N. main St. Atmore, AL 36502 Catalog is $20 + $3 shipping. No website.
Go to any mag store, look at his ad in Hot Rod. I see it in the latest issue, pg 129.
You scored great! Hope your car sells for a fair price.
Contact me off line if you want me to write copy for your car to sell on Ebay.
Chat Soon,
KED85
Karl
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
