top mount m62 supercharged v6 camaro
Old May 4, 2011 | 04:52 PM
  #51
mikeal8208's Avatar
Car: 1991 camaro RS
Engine: 3.4-3500 hybrid + Vortech V1 S-trim
Axle/Gears: 4.11 soon
Re: top mount m62 supercharged v6 camaro
here is some more progress
Old May 4, 2011 | 04:53 PM
  #52
mikeal8208's Avatar
Car: 1991 camaro RS
so i got the bolt holes for the super to bolt on drilled and i tapped the threads into the intake manifold. I also made the first cut for the air passage... here is a idea for improving the looks of the blower and bl85c i haven't wrote any code for the 165' if that was your question to me??
I know its a civic
Old May 5, 2011 | 05:37 PM
  #53
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
I was adressing street lethal. And that's a cavalier.
Old May 5, 2011 | 06:26 PM
  #54
mikeal8208's Avatar
Car: 1991 camaro RS
Oh I see now it's a eco tech not a v tech
Old May 30, 2011 | 11:13 AM
  #55
19camaro83's Avatar
Car: 1983 camaro sport coupe
Engine: 2.8l v6 - stock motor
Transmission: NWC t-5
Axle/Gears: whatever came stock (?)
Did you ever finish your build?... you just kinda.. dropped off the radar.. lol.
Old Jun 2, 2011 | 11:33 AM
  #56
project89's Avatar
any updates man?
Old Jun 5, 2011 | 10:00 AM
  #57
mikeal8208's Avatar
Car: 1991 camaro RS
Sorry my project has been put on the wayside for getting graduation requirements and last minute teacher projects I had to get done... I have the plate milled and mounted to the intake manifold but I still have to get some money and get a wide band o2 sensor and the fmu and do the tubing for re routing the throttle body, I have decided how im going to move the TB and where its goin to go ill run up some pictures of that when I can
Old Jun 5, 2011 | 10:57 AM
  #58
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Just a couple of thoughts...
I am NOT an EFI or ECM programming professor, but depending on where you got that blower from, those 21# injectors might not work right. Last time I used Buick (or GM 3800) injectors, they were "peak and hold" type injectors and were not exactly compatible with the mpfi V6. A friend did something with some Radio Shack resistors and used them, but I don't know what that was!!!
And, maybe instead of the intake you're using (I know you're on a budget) why not go to the wrecking yard and get the 2.8/3.1 carb or TBI intake to use? I know my TBI intake was also aluminum, and it seems it would be easier to adapt? With all the milling you are doing, you are obviously talented enough to cut off the injector bungs and TIG them onto the TBI intake. I'm just saying...
I am subscribed to see how the frankenstein project comes to life!!
Good luck!!
Old Jun 5, 2011 | 11:05 AM
  #59
KrisW's Avatar
Engine: 2.8/TBI/TPI
Old Jun 8, 2011 | 12:46 PM
  #60
mikeal8208's Avatar
Car: 1991 camaro RS
Thanks for letting me know the 21 lb injectors wont work unless u do something with a resistor... it would be great if u could find out how he used and what size resistor he used Uhm ill see what I can get for a pictures to post up on where im at
Old Jun 8, 2011 | 04:17 PM
  #61
project89's Avatar
it will be easier to just get the right injectors, basically u would build 2 resitor packs and wire them up so the ecm sees the low x injectors as high z injectors.
alls the resitors do is increase the ohms the ecms sees
goto the junkyard and find a 350/305 tpi motor and snag the injectors out of it
edit
lol i almost forgot i have a fairly new set of 21's i pulled out of my iroc that i replaced with precision 65# injectors
i was asking 50$s for them if u want them, (set of 8)
btw diyautotune has the inovate mtx-l on sale for 189 bucks its an upgrade from the old lc-1 units and feedback has been great on them
http://www.diyautotune.com/catalog/i...844-p-467.html
Old Jun 18, 2011 | 08:51 AM
  #62
mikeal8208's Avatar
Car: 1991 camaro RS
Old Jun 18, 2011 | 09:02 AM
  #63
mikeal8208's Avatar
Car: 1991 camaro RS
Putting these pictures and stuff up with my phone so bear with me Haha... but I got some of the gauges ill be using but, all that I should have to have to get started... but I need some help deciding exactly which fmu to use... I have heard that the vortec is good but which one there's like seven of em...
Old Jun 18, 2011 | 06:10 PM
  #64
project89's Avatar
with 21# injectors u want a 2 to 1 fmu
Old Jun 19, 2011 | 03:43 PM
  #65
mikeal8208's Avatar
Car: 1991 camaro RS
Ok so im looking at the vortech 6x100-003 it can do four preset ratios the lowest bieng 2.5:1 I think I may be able modify it to 2:1 anybody have any expirence with this sfmu? Jw if it has any problems
Old Jun 19, 2011 | 04:44 PM
  #66
project89's Avatar
the vortec adjustable is a good unit, with a simle bleeder valve.or cheao boost controller u can actually fine tune them
Old Aug 21, 2011 | 02:53 PM
  #67
mikeal8208's Avatar
Car: 1991 camaro RS
been a long time since i posted up any progress here but this is what im up to now on this.... first off i switched to my now "project" vehicle so i can have it apart for the few days ive been working on things
there is what will be out of the hood
I drilled the holes to mount it to the intake plate
and now i am fabricating the intake tubing to the throttle body
the only thing i found about switching vehicles is that this vehicle's drive pulley is larger and is going to push the m62 to the max... which will be 12+ psi at 6000 rpms
Old Aug 21, 2011 | 10:07 PM
  #68
project89's Avatar
lookin good man id get rid of that kink bend ex tubin thouh, get urself 2 mandrel u bends,also make that pipe as short as possible so u can mount the tb as close to the blower as u can
Old Sep 8, 2011 | 08:32 AM
  #69
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
anything new i just went through whole post and looks and sounds great!
Old Jun 7, 2013 | 11:44 AM
  #70
mikeal8208's Avatar
Car: 1991 camaro RS
Just to let people know I dropped this project I had it together but the blower was off at a slight angle from the engine drive pulley and the belt wouldn't stay on... With a better milling machine (than I used) and some more thought on the design possibly with an adjustable mounting system (between the S/C and intake) this is entirely possible I went to a different setup with a v1 vortech centrifugal supercharger. I may come back to this someday just to see if I can make it work.
Vortech build if interested
https://www.thirdgen.org/forums/v6/6...ise-3-4-a.html
Old Jun 8, 2013 | 01:45 AM
  #71
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
need slotted hole downs for fine alignment, no car would be 100% dead on anyways.
Old Oct 13, 2017 | 10:39 AM
  #72
transamgtagiy's Avatar
Car: 1989 trans am clone
Engine: 2.8 v6
Transmission: t5
Axle/Gears: 3.72
Have any of you guys tried to put an m112 supercharger on a 2.8? I'v heard of people putting them on mustangs and I wonder if I could put one on my 89 trans am with the 2.8.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
