Code 43 help needed
Old Apr 14, 2011 | 03:54 PM
91camarolover's Avatar
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
Code 43 help needed
My 91 rs 3.1 is my daily driver and last summer it started giving me code 43 so I replaced the knock sensor and that worked for a while but 3-4 months later it came back on. As far as drivability I doon't notice it a whole lot but when the car is warm theres a little bit of an intermittent miss that happens on occasion. I don't know if thats realated or not but I'm putting new plug wires on and getting a new ignition coil and will clear my codes soon but if anyone else has this issue or any other ideas let me know. Thanks!!!!!!!
Old Apr 15, 2011 | 07:41 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Code 43 help needed
Do a full tune up and then clear the code to see if it comes back. In the case of code 43, there aren't many things that go bad in the 90-92 cars. It's either the sensor, the wire between the sensor and ECM (including the connector), the ECM, or the MEMCAL. There is no ESC module on the 3.1 as the board is inside the MEMCAL...
Old Apr 16, 2011 | 12:10 AM
Ok I did a tune up last year but didn't do wires and the sensor was new last year too so I'll try wires and see what happens
lee01
Apr 9, 2016 01:56 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
