Temperature Gauge
Old Mar 29, 2001 | 06:20 PM
sgtpanther's Avatar
Temperature Gauge
I did a 2.8/3.4 conversion on my 89 firebird..and now my temperature gauge with not work..can anyone help...i put in a new coolant sensor.
Sgt Panther
89 Firebird..2.8/3.4 conversion
Old Mar 30, 2001 | 05:08 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The coolant temp sensor for the gauge is in the front outer corner of the driver's side head. It's behind the a/c compressor, and near the lip of the valve cover. It's got a green wire going to it... did you forget to hook it up?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 1, 2001 | 03:20 PM
sgtpanther's Avatar
no I hooked it up...I did not change it..till I seen that the gauge was not working....and other ideas?
Sgt Panther
Old Apr 1, 2001 | 07:47 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
wait...theres 2 different coolant sensors, one on the front of the block next to the thermostat, the other that attaches on the head..which did u replace? They both do totally different things
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
Old Apr 2, 2001 | 01:30 AM
HIX5000's Avatar
Is the guage pegged out? If so it's probably the guage.
Old Apr 2, 2001 | 08:16 AM
sgtpanther's Avatar
no the Gauge is not pegged out..........I replaced the one behind the AC unit..in the block...should I replace the other one too?
Sgt Panther
Old Apr 2, 2001 | 09:56 PM
Luke's Avatar
Car: '86 Camaro
Engine: 2.8 MPFI
realy......what the second one for? Is it under the throtle body?
Old Apr 3, 2001 | 06:07 PM
KED85's Avatar
Hey
try this idea!
Ground out the wiring.
See if the gauge reacts. Like peggin it.
On my 1974, I do not have the oil pressure sensor wiring hooked up to a sensor in the block. Because of that my gauge is pegged (circuit open) all the way past the highest reading (I just double checked).
Maybe somehow the wiring got discombobulated during to engine relocation (the in-n-out action). Trace the wiring!
I forgot, all other gauges work?
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Apr 3, 2001 | 06:35 PM
KED85's Avatar
Get a NEW connection for the sensor. That's what ya need, I'll bet!!
Chat Soon,
KED85
Karl
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
