Quick question
Old Apr 4, 2001 | 06:24 PM
Ovrclck350's Avatar
Quick question
I measured from my rear tire to the top of the fender wall, and my right rear is lower than my left rear. Also sometimes I can go over a bump and hear a LOUD clank from back there, any suggestions?
Old Apr 4, 2001 | 06:29 PM
v6camaroguy's Avatar
I suggest you get new shocks and springs
88' CAMARO Sport Coupe
2.8L V6
K&N Air Filter w/RAM AIR
Flomaster
Old Apr 4, 2001 | 06:42 PM
Ovrclck350's Avatar
I have new shocks.
Old Apr 4, 2001 | 06:48 PM
AlexJH's Avatar
Engine: 5.7L V8
Same pressure in the tires?
For the clunk, do you have the spare/jack secured properly?
Just want to get the easy stuff figured out first
Old Apr 4, 2001 | 06:55 PM
Violate 3.8's Avatar
is the sway bar hooked up right? go under and start pulling on suspension pieces and see if anythings loose....if you find something then thats likely the culprit
Old Apr 4, 2001 | 08:08 PM
Ovrclck350's Avatar
No spare tire or jack, and yes, the tire pressure is the same. nothing loose either.
Old Apr 4, 2001 | 08:16 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I have a simlar paroblem lie that too but inside if i sit on the driverside of the car in the back seat im fine by 2 inches if i go to the passanger back seat my head hits any ideas?
Old Apr 4, 2001 | 08:29 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
ummmm....maybe the passenger bottom is not all the way in and its sitting up higher..maybe ur roof is sagging (headliner)
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
Old Apr 4, 2001 | 09:30 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
check and see if your track bar brace is loose. it could cause noise. as for the height, the only thing that determines it is the springs which are "supposed" to sit exactly the same way in relation to each other. maybe they're not?? probably wouldn't make much difference now that i think about it but you never know.
Old Apr 5, 2001 | 09:46 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The exhaust's I-pipe could be hitting the track bar brace when the suspension compresses all the way. Maybe the right rear exhaust hanger is loose or rotted away?
Eep- or, your upper shock mount busted through. If you pull the carpet back and don't see the upper bolt for the shock... don't panic too much; mine both busted through. I rebuilt 'em with 1/4" of steel plate bolted up there.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
