How much extra power with these goodies?
Old Apr 9, 2001 | 06:42 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Ok last Saturday I took advantage of that discount from Summit and ordered some goodies for my 2.8. Question I got is obvious...how much power should I expect when everything's in the Camaro?
K&N air filters (the 2 drop-in tht go over the radiator, with those little shields removed)
Catco hi-flo cat converter
Dynomax cat-back #17943
MSD-6 ignition
MSD GM blaster coil
MSD heli-coil wires
In addition to how much power, I got one more question:
Recommendations for a good cap and rotor, and what spark plugs should I use?
Old Apr 9, 2001 | 08:35 AM
Brian K's Avatar
The Dynomax and Catco should be good for 3-7HP. The K&N's should give you 1HP. The ignition sutff will provide better throttle response, better gas mileage due to more complete combustion. In the terms of HP 1, but overall a nice thing to have especially if NOS is in your future.
Plugs use the STOCK ONES.... AC DELCO gapped just a hair wider. If stock is .45 then .47 or .46....
Old Apr 9, 2001 | 08:50 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, you'll definately feel a seat of the pants boost from these mods! I agree with Brian; the stock plugs are fine, and since you've got the MSD, you can go a big larger on the gap.
I use Accel's cap & rotor, part #8132, but I hear the AC/Delco one is just as good. In fact I might use the AC/Delco one for my next major tuneup.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 9, 2001 | 01:36 PM
Kyle F's Avatar
If you have the extra money get the AC Rapid fires. They are a little better for a few reasons, maybe in the tune of 1 hp or 2, but nothing major. You could actually open you gap up by .05" over stock with a complete ignition upgrade. That is where you will get your extra HP form your ignition because you are introducing a larger spark to you combustion. The components just allow you to get tha larger spark there.
FOR SALE!!!!!!!!!!!!!!!
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil,MSD Wires, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added.
Stereo has 2 Clairion Pro Audio dash plates, 2 Sony 6X9s, 2 Kicker 12's in a custom Carpeted box with a custom amp rack Holding 3 MTX 280 Amps, and a MTX electronic Crossover all wired with EFX cable.
Asking $4200 with all extra Parts that are needed to fix most apearance flaws. ie Complete hatch and wing from a 91 GTA
http://geocities.com/feltsb/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/2 ton 350, one of those NASCAR F150's
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Old Apr 9, 2001 | 02:15 PM
RenoLB8's Avatar
I like splitfire plugs, myself, and use Accel for everything else ignition. Of course, right now I'm having major ignition failure, so maybe that should come under consideration...
Anywho, I heard that the stock gapping is incredibly conservative, so I ovegapped mine either .05 or .1, I can't quite remember, and they ran fine for two years, the first with a stock coil.
-Reno
'88 Firebird LB8
"Cerberus"
-Supercharged Hybrid LB8/L32 Project-
"Got a green light, got a red light, no cop, no stop, man I don't care, every one of you could be the same, every one of you could play this game, got a green light, got a green light but you're going nowhere..."
http://www.angelfire.com/il/Firebird28/index.html
jhawkeye
May 25, 2022 06:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
sailtexas186548
Aug 24, 2015 10:11 PM
InfinityShade
Aug 22, 2015 08:00 PM
