car died! HELP!!!
Old Apr 30, 2001 | 07:46 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
car died! HELP!!!
i put 6 gallons of reg gas in my car today. i got it from the place down the street, where i always get it. i drove for like 10-15 mins after, and when i pulled into my street the damn thing died on me! i pulled to the side of the road and started it up, and it ran rough so i revved it, and it died again. i drove it 50 feet to my house (with almost no power brakes or steering) and checked under the hood. the coil wire was loose so i put it back on and drove it, and it was fine till about 4000 rpm, then it hesitated and dropped to 3000 then up to 4000 a coupla times, and then it just kept jumpin around on the way back. anybody have any ideas?
Old Apr 30, 2001 | 10:07 PM
ChevyGuy87's Avatar
Engine: 4.0
could it just be bad gas? my engine light didnt even come on, and im not throwing any codes. i could really use some help here
Old May 1, 2001 | 03:04 PM
KED85's Avatar
Vacuum leak.
Start searching.
Sounds like the one by the distributor on the intake manifold.
Why would the coil wire "suddenly" come loose?
Who has been playing around there?
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old May 1, 2001 | 04:21 PM
ChevyGuy87's Avatar
Engine: 4.0
i got a new fuel filter and was gonna put it in today, but i cant find the fuse that sends power to the fuel pump so i cant drain the line. anyone know which one it is?
Old May 1, 2001 | 08:02 PM
ChevyGuy87's Avatar
Engine: 4.0
would a filter even cause it to sputter severely all the time? i dont want to do a new pump, so im hoping against hope its the filter
Old May 2, 2001 | 10:25 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I always just removed the filter... gas would start dripping out, and I'd wait & wait, and just when I got way too nervous, the gas flow would stop.
But now, something's different. Now, the gas flow doesn't stop. I assume it has to do with the Borg-Warner replacement fuel pump I put in. So now I'm like a madman under there... undo the old filter, quick put the new one on- and gas burns skin... ouch.
Make sure when you do the fuel filter to check for the o-rings on the extreme ends of each steel fuel line. Sometimes the o-rings can stick inside the fitting on the fuel filter. If the o-rings aren't on each end of the steel line, you'll get a leak.
Don't smoke, or weld, or throw steel wrenches on the ground (sparks), or work around a hot exhaust, or work inside a garage (gas fumes build up) when you do this!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 2, 2001 | 04:29 PM
ChevyGuy87's Avatar
Engine: 4.0
well i just put the filter in and it wasnt that. and while i was driving it after it stalled twice. i gotta get a diagnostic computer and hook it up, cuase i cant figure it out. would a faulty fuel pump set off the service engine light? i hope so, cause the light isnt going on and i dont want to do the pump
Old May 2, 2001 | 06:11 PM
ChevyGuy87's Avatar
Engine: 4.0
i just realized that the service engine light was blown, and when i put it in it flashed 3 codes: 33, 34, 45. i really need some help!
Old May 2, 2001 | 07:49 PM
ChevyGuy87's Avatar
Engine: 4.0
it was the mass air sensor
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
