4th Gen Springs
4th Gen Springs
Ordered some SLP-Take-off's for 35.00 front and rear, and I'm just makin sure that I can use the rears. I already have the fronts sold for $20.00. So I'm gettin springs with 2 miles on them for $15.00. How hard are they to install?
Car: 1986 Firebird
Engine: 2.8 V6
The rears are easy... you raise the car, and support it on jackstands by the framerails. There's a spot right in front of the rear lower control arms. Then you raise the axle up a bit with a hydraulic jack, and remove the lower shock-to-axle nuts. (You might need a back-up wrench in case the whole nut/bolt starts spinning). Then you slowly lower the axle.. there's a point where there'll be no stress on the lower shock bolt, and the shock bolts will almost "slide" out of the axle. (some light hammer tapping might help.) Lower the axle some more, being careful to not "hang" the axle by the lower shock bolts, and to not put stress on the rear body-to-axle brake hose. Then you reach up, pull the old springs (and insulators) down, put the new springs up with the old insulators, and reverse the deal.
Why didn't you keep the front springs? (Just curious) My springs are probably all shot to hell by now; $35 sounds like a great deal. Oh- wait- those are v8 springs, aren't they? Is that why you're not keeping the fronts?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Yes, they're V8 Springs, plus, I thought that the front suspension stuff wouldn't work on our cars from a 4th gen. Am I wrong? Would 4th gen V6 springs work on my front? If so, the guy I'm selling the v8 front has v6 fronts on...i can get his probably for free.
Car: 92 Formula
Transmission: A4
Fronts wont work.... I have been told this by many people... different sizes and placement and junk like that... Rears work, fronts dont...
Later!
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Later!
92 Rs 3.1/T-5
AIM : Theonekiztope
ICQ: 8787542
Car: yep
Engine: uhuh
Transmission: sure does
kiztope is correct. I can tell you for sure, having owned and swapped both 3rd gen and 4th gen springs....the 4th gen fronts do not work on a 3rd gen.
Totally different.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Totally different.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
3rd gen front = strut suspension
4th gen front = Double A arm suspension
1999 30th anniv. TransAm #877
** BESTS:60ft=1.935 1/4 ET=13.08 MPH=111.8 ** (Only 3.5K miles)
T-TOP,6M-Hurst,12cd, TCS
!EGR * !MAF Screen * ported and polished MAF * !silencer baffles * ! lid baffles * ported and polished TB * removed primary and secundary baffles * sealed ram-air * 9.4k timing-tricker * !CAGS * Mobil 1 * Lou's short stick * BMR panhard rod * BMR poly/poly LCAs * !DRL * Polished SLP resonator catback * 2 Ractive mufflers * 3x3 'fernco' mod * K&N * TB stop grind * Grotyohann headers * offroad Y-pipe* Power pedals * 19+ coats Zaino * WHITE gauges cluster * blue door TA badges * pontiac windshield decal * Polished momo shift **** * 4.5" brosal exhaust tips * Kenny Brown DD SFC
Ordered:
Polished: Calipers * Hood struts * Air tubes * Valve covers,Heat shields , etc.
Later:Cam + spring + pushrods swap + stage II heads
2000 Black Z-71 K1500 5.3l
ext.cab * !intake baffle * !MAF screen * !EGR mod
Ordered:
ambainb
Apr 25, 2016 09:21 PM
lol
