how much Horsepower gain ?/
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, intake & exhaust won't add a ton of HP, but they should add enough to be felt. Do both and you squeeze a bit more out of the deal, since the engine can move air through itself easier.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
not tring to **** you off, or prove you wrong yet again tomp but ..well...I have the same thing on my car and well...no nothing can be felt by it. Maybe 3-4 poines. and 1-2 MPG...and not to mention more intake noise...sounds like a hoover on steroids.
[This message has been edited by Camaro_hunter_d (edited April 25, 2001).]
3-4 ponies would not be easily felt by SOTP alone...
1999 30th anniv. TransAm #877
** BESTS:60ft=1.935 1/4 ET=13.08 MPH=111.8 ** (Only 3.5K miles)
T-TOP,6M-Hurst,12cd, TCS
!EGR * !MAF Screen * ported and polished MAF * !silencer baffles * ! lid baffles * ported and polished TB * removed primary and secundary baffles * sealed ram-air * 9.4k timing-tricker * !CAGS * Mobil 1 * Lou's short stick * BMR panhard rod * BMR poly/poly LCAs * !DRL * Polished SLP resonator catback * 2 Ractive mufflers * 3x3 'fernco' mod * K&N * TB stop grind * Grotyohann headers * offroad Y-pipe* Power pedals * 19+ coats Zaino * WHITE gauges cluster * blue door TA badges * pontiac windshield decal * Polished momo shift **** * 4.5" brosal exhaust tips
Ordered:
Kenny Brown DD SFC
Polished: Calipers * Hood struts * Air tubes * Valve covers,Heat shields , etc.
Later:Cam + spring + pushrods swap + stage II heads
2000 Black Z-71 K1500 5.3l
ext.cab * !intake baffle * !MAF screen * !EGR mod
Ordered:
Kenny Brown DD SFC
<font face="Verdana, Arial" size="2">Originally posted by Camaro_hunter_d:
[This message has been edited by Camaro_hunter_d (edited April 25, 2001).]</font>
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
I doubt that. When I added the 2 K&N's to the RS and took out the baffles I noticed a difference. I dare say that if you're running an open airbox with a decent air filter, you should get at least 5-7 HP.
Jason E
'89 Camaro RS 2.8
Medium Grey Metallic
2.8, A4, T-tops, 90k miles
'97 Z28 w/30th Anniversary package
LT1 (obviously), 6 speed, t-tops
White with orange stripes, killer system, 41k miles
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
Jason E
'89 Camaro RS 2.8
Long Live #3...
<font face="Verdana, Arial" size="2">Originally posted by Violate 3.8:
Imagine that, not everyone's car is the same. Tom noticed some SOTP difference and you didn't so that means that he is wrong and you have to jump on his back. Quit being a fu(king a$$hole camaro_hunter. You are still pissed about that whole engine/coolant temp thing aren't you, trying to get in one last word. This forum is meant for everyone to share DIFFERENT results and opinions. You aren't god, and your car isn't every man's car so if you have nothing constructive to say, then don't.</font>
[This message has been edited by Camaro_hunter_d (edited April 28, 2001).]
Violate is NOT TomP. And just to have some hard PROOF for you ( I didn't doubt I was right ) I checked their IP's. Just because GM made all engine's doesn't mean that they all react the same. Otherwise, ALL engines would fail at the EXACT same time. Engines break in different, and plus, who's to say that a difference to Tom would really register on your differences book. Tom has earned my respect by posting knowledgable information and admiting when he's wrong. Personally, I didn't notice a difference even when I removed my clogged filter, but then again, it takes a BIG difference for me to even notice one. I don't notice small variations in the engine as well as others. Camaro hunter, just chill out a little bit. This feud between you and Tom needs to be put to rest. No need to bring up the past.
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
I felt a minimal gain when I gutted my air boxes, but I did *feel* a gain... and even a minimal gain is profitable when it costs nothing to do =)
HiPo filters will open that up a bit more, also.. probably another minimal gain.. probably not worth it for the money.
A decent cold air intake would open it up further yet. Probably a felt gain over the gutted airbox. DIY should cost as much (if not less) than stock-replacement K&Ns.
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
In search of new v8 engine & transmission, now contemplating t5 swap to get me out of this mess.
Misc Mods: Cut air box, '83 Firebird spoiler.
Performance Parts: MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers.
Audio Mods: Pioneer DEH-P3000, two 12" Optimus Pro Audio subs in hand-made enclosure each powered by a 260 watt Optimus amp. Working on shaving the box for weight.
My Homepage, with pics.
sorry overclck but I am getting sick of getting bashed for what I say. The originater of this post was wondering what this mod did..I stated what it did to my car. Then Vibrator flamed...
and it seems that I am not the only one that felt little if anything for this mod. And sorry t say that one can change their IP by getting off line then coming back on. A freind of mine Jerry works for Earthlink.
[This message has been edited by Camaro_hunter_d (edited April 29, 2001).]
Actually......my IP's always the same, and everyone I know's IP is always the same. Just getting offline and back on does NOT change your IP address. Don't believe me? Explain this one. I reformated my computer completely, took EVERYTHING off, and guess what, my IP, is hmm....still the same as before. And I wasn't flaming you, I agreed that I felt no difference, but then again, i know guys that swear to me up and down about feeling it. It's all how you perceive "a difference".
Just to settle the IP issue. Since this is a Car post and not a comp post, The IP changes if you have a dial up sevice and stays the same if you connect through an "always on" sevice like DSL or Cable , T1 and so on. I read this out of Popular Mechanics.
I'm on a cable connection Fu(ky, and I AM NOT TOMP. I'm sure you moderator knows a little more about the IP's than you do camaro_hunter. BTW, I felt a SOTP difference when taking the cover off the air box (just while street racing). It gets much more air at high rpm's and even felt a little stronger on the low end for some reason. I'm sure the 3.8 has a larer gain cause it sucks more air, but I would bet that the 2.8's can also feel it.
Car: 1986 Firebird
Engine: 2.8 V6
I'm sure, too, that the first two octets of the IP address will show the difference in geographical location. I haven't taken any weekend trips to the middle of the country...!
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
I see youre hiding behind a self invented screen of bullsht camaro huntd. I read what you wrote to Tom P in your first post and you deserve to get flamed for running your mouth. Im sure youve done enough engine swaps to argue with us all and taken the air boxes off enough engines to get an accurate representation of the results
and NO THIS ISNT TOM OR VIOLATE 3.8!
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
.and NO THIS ISNT TOM OR VIOLATE 3.8!
<font face="Verdana, Arial" size="2">Originally posted by vortecfcar:
</font>
</font>
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
dbrochard
Sep 25, 2015 04:56 PM
