no power
Old May 25, 2011 | 08:52 PM
ktmracerx009's Avatar
Car: 1987 Camaro
Engine: 2.8 tpi
Transmission: 5 speed
no power
hey guys i have an 87 2.8 ltr and i reneclt re biult the back end on it and it ran fine for a bit i bought some spark plugs to do a little tune up.
this morning my mom drove my car because it was last in the drive. on the way she said that my car died and then after it started it would drive but had no power. when she got home i pulled out the drive and it is driving like it has 10 HP. i too and replaced all the spark plugs making sure to set all gaps at .045 and drove it again and the same thing, i can get a top speed of like 20
any ideas im traveling and really need it runing
Old May 26, 2011 | 06:30 AM
ex-x-fire's Avatar
Re: no power
Get a fuel pressure tester & test it, the connection is back by the dist. cap. You might be able to rent one from autozone, pressure should be above 35psi.
Old May 26, 2011 | 08:00 AM
Car: 1987 Camaro
Engine: 2.8 tpi
Re: no power
ok il check that out,
could it be the fuel filter?
Old Jun 6, 2011 | 11:43 AM
Car: 1987 Camaro
Engine: 2.8 tpi
Re: no power
ok i replacede the fuel filter and still the same thing.
could it be that putting in the K&N air filters with the cheap ram air job is giving the computer too much air?
Old Jun 6, 2011 | 02:56 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: no power
No....and we need more information, does it start normally, does it idle normally, does it still rev high, does it make any weird noises etc.
Old Jun 6, 2011 | 04:28 PM
Car: 1987 Camaro
Engine: 2.8 tpi
Re: no power
yes it starts right up and has a bit of a rough idle then smooths out and idles normal, the orignal noise i thought i heard was just the new airfilters getting in the air ( the old ones were smashed and rusted)
Old Jun 6, 2011 | 10:23 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: no power
Again, check the fuel presure. I'll bet that's the problem.
Old Jun 7, 2011 | 09:50 AM
Car: 1987 Camaro
Engine: 2.8 tpi
Re: no power
ok if the fuel pressure is low what would be the problem?
Old Jun 7, 2011 | 10:17 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: no power
something blocking the flow, could be a fuel filter, pump could be dying, ect
Old Jun 7, 2011 | 02:24 PM
project89's Avatar
Re: no power
its a v6 car its slow and has no power to start with
seriously though try unplugging the mass air sensor and then see what it does
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
