Catalytics
Old May 16, 2001 | 10:10 AM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
Catalytics
I have determined that my Cat is clogged & needs to be replaced. I was quoted these prices:
Universal Fit $61 ($96cdn) some mods needed
OEM $99 ($149cdn) no mods needed
Walker Hi-Flow $97 ($145cdn) some mods needed
I would like to go with the Walker Hi-Flow but I am wondering how good these are... everyone here seems to have either Dynomax or Flowmaster. Also how hard is it to install one; will I have to take the car in?
I have searched this site & haven't had much luck finding any info
thanks, Don
aka CanadianCamaro
aka Z2point8
Old May 16, 2001 | 10:54 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Don (thanks again for the book website!), I bought my hi-flow cat from Summit for $67 US. It was made by Products for Power... I don't have the part # handy, but the Summit guy got it to me quick. Here's the important stuff- the cat convertor was a direct bolt-in! It had the same inside-diameter for my stock y-pipe, and it had the same flange for my I-pipe. It even re-used the stock hanger at the back of the cat!
If you can dig that up thru Summit, you can get a bolt-on deal. If I remember, when I get home, I'll dig up the part # for you for tomorrow.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 16, 2001 | 11:03 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Damn, did a look at Summit's web site, and PFP is no longer listed on their manufacturer search. But, I did get a find I think you'll like!
Catco! Part #CTO-4115. I did a "Manufacturer Search", and on the top of the search screen, I told it department = "Exhaust", section = "catalytic convertors", manufacturer = "catco". A list popped up. I chose our setup, which is a 2.5" in, and 2.5" flanged ball outlet. A box popped up- and the cat looks like mine. I clicked on applications, and there it was, standing out at me- 82-92 Camaro 2.8/3.1 ! If the pic & and description (flanged ball out) is right, this is the bolt-in cat you need. Oh- price was $83 US... but no mods needed!
Old May 16, 2001 | 11:15 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I have a Walker High Flow CAT works perfect.... Also Walker if i rember correctly is Basicly Dynomax but they just use a different name sorta likea pontiacs 3.1 and a camaros 3.1 same ting same company just ones by pontiac....
Old May 16, 2001 | 11:16 AM
FAST RS's Avatar
Oh I had mine installed at a muffler shop the have to weld some stuff on and do some things becasue its smaller hen the stock CAT.
Old May 16, 2001 | 01:44 PM
FAST RS's Avatar
TOM i head that the Catco Cats werent that good ve herd that thay last on average about 2 years.
Old May 16, 2001 | 02:29 PM
Ovrclck350's Avatar
Walker is Dynomax.
Old May 17, 2001 | 04:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Really? Wow, 2 years is short! Thanks for the tip!
Old May 17, 2001 | 06:14 PM
FAST RS's Avatar
I herd about the 2 year thing on a post somewere on the board if i remeber correctly it was the one can a v-6 beat a 305 and then it got into catalytic converters im pretty sure that was the post tho but dont quote me.
Old May 17, 2001 | 06:28 PM
F-BOY's Avatar
what shop did you get that priced at, and also was that installed?
Old May 18, 2001 | 12:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh Man I remember that post... the post that wouldn't die... hehe
Old May 18, 2001 | 03:19 PM
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
I wenrt with the walker cat, for the price it was the best buy... with the canadian $ so low, I didn't want to mail order from the US. It took me about 1.5hrs or so for installation, most of that time was removing the old cat... It didn't want to come away from the Y-pipe. I only had to cut off 2 inches off pipe to make the new cat fit (it was bigger) & then it bolted right up, I was even able to use the hanger.
I've noticed a bit more "pep" now that the engine is breathing right. No all I have to do is get rid of the code 34 (all signs point to a new MAF needed, thanks Tom for the diagnostic method you posted awhile ago)
Old May 18, 2001 | 04:32 PM
KED85's Avatar
Wiggle the wires.
How is your timing?
If it's shot, you engine may ping alot!
MAF affect timing.
I still have my Performance for Power cc, I got my from Don's Hot Rod Shop in Tuscon. 800-888-8892. About $60, 10 years ago. Mine on my S-10 Blazer still passes emissions with it.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old May 22, 2001 | 05:57 PM
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
I've been talking to a few people & reading up on it a little. Turns out that a vaccuum leak can cause it to throw MAF error codes.... It makes sense tough, I started having MAF problems ever since I changed the Valve Cover Gaskets (had to pull apart the intake/plenum/TB) so maybe I'll pull it all apart & re-do the gaskets; maybe actualy use gaskets instead of Blue RTV
Old May 22, 2001 | 08:43 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
<font face="Verdana, Arial" size="2">Originally posted by FAST RS:
I herd about the 2 year thing on a post somewere on the board if i remeber correctly it was the one can a v-6 beat a 305 and then it got into catalytic converters im pretty sure that was the post tho but dont quote me.</font>
Hey thanks FAST RS, i had finally forgotten that post.....j/k You suck Monkie!!!!!
PurelyPMD
May 5, 2016 04:57 PM
1992Z28!
Nov 19, 2015 07:33 AM
Eric-86sc
Sep 22, 2015 08:25 PM
m00n420
Sep 11, 2015 02:39 PM
89fast5oh
Sep 8, 2015 09:55 AM
