Girl Having Problems W/ 3.1
Old May 30, 2011 | 10:23 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Heres a copy and paste from a girl having problems with a 3.1...
Ok fb people, I have a 91 camaro that wont start, It has new everything, and we have found out its electrical, I put a new PCM in it but its still not running, we got it running once then when we hooked the exhaust on it stopped running again, i am wondering if the PCM needs programed or maybe it needs a new chip because the fuel injector wont fire at all. HELP PLEASE!
Havent seen the car in person and I know this isnt much to go off of but with whats here what do you guys think? No one seems to be able to correctly troubleshoot it and are telling her to do a v8 swap. She says it has a new dizzy and the timing is good.
Old May 31, 2011 | 12:16 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Girl Having Problems W/ 3.1
Originally Posted by armybyrd
... then when we hooked the exhaust on it stopped running again...
Are you saying it runs with the exhaust off but not with it on? If so take the exhaust off again and make sure it's not blocked anywhere, especially the catalytic converter if it still has one. If not that exactly how does it not run? Does it fire then die immediately? Not fire at all? Not much to go on yet. And suggesting a v8 swap as a solution is just plain lazy and very helpful.
Old May 31, 2011 | 12:37 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Check the basics.
Fuel and spark, then go from there.
Old May 31, 2011 | 01:37 AM
Sheriff420's Avatar
Car: 91 Camaro rs
Engine: 3.1
Tell her to test all of the fuel injectors.
Old May 31, 2011 | 07:57 AM
southbay08's Avatar
Use a noid light to see if the injectors are pulsing, and then check the resistance. They should be at least 12ohm or more.
Old May 31, 2011 | 10:07 AM
Sheriff420's Avatar
Car: 91 Camaro rs
Engine: 3.1
If the injectors turn out to be the problem then tell her to get re-manufactured injectors from SouthBay. I did and my Camaro is back on the road now after sitting for about 6 months.
Old May 31, 2011 | 03:17 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Need to make sure that VATS (anti-theft) doesn't have an issue. Pull the codes from the ECM and check for a code 46. VATS also disables the fuel injection as well as the starter.
Yes, the car may crank, but that doesn't mean that there isn't an issue with the wire at ECM pin F10 (bottom of the yellow ECM connector, opposite the retaining clip) that provides the VATS signal to the ECM.
Elephantismo
Feb 13, 2019 12:51 AM
trutilldeath246
May 11, 2002 09:43 PM
SSC
Mar 10, 2002 01:16 PM
drt-rcr
Aug 27, 2001 06:57 AM
