VSS buffer
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
VSS buffer
Can anyone tell me where the VSS buffer is on the 92 V6?.... I thought it was behind the passenger side dash but I do not see it.
Thanks.
92 Camaro RS
89 Iroc-Z Convertible
Thanks.
92 Camaro RS
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
i thougt the vss was under the pass. dash (in the ECM) there's a tech article about removing the governer if youre curious about that.
Engine: 409 SR
Nope not interested in that at all. There should be a buffer somewhere to knock the signal down from 4000 pulse to 2000 pulse for the cruise control. Sitting in the passenger seat there a dash, then behind that there is the ECM, then behind the ECM there is black box. I think this is it but I am not positive about this.
Anyone?..
Anyone?..
My VSS buffer is attached to the ECM Carrier in a yellow box. The only black box related to the cruise control on my Bird is the module which is behind the pass. dash just below the "Map Pocket."
Just a little food for thought.
Dale
1986 FireBird
2.8L MPFI
Gutted Cat, No muffler (Sweet Sound)
Was 700-R4 --> Now T5
Dale
1986 FireBird
2.8L MPFI
Car: 1986 Firebird
Engine: 2.8 V6
A '92 V6 will definately have the electronic speedometer; so the yellow box behind the speedometer (on 86/87-below f-bodies) won't be there.
Don't know where the buffer would be, though. I always assumed it was made integral with the computer.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Engine: 409 SR
oops, my mistake. After reading Tom's post I went back to look at the wires coming out of the ECM. I mistaken the red wire going to the cruise control module which is the black box behind the ECM as a power lead. In fact it is the 2000 pulse/mile signal wire. Sorry for the confusion.
Thanks for the replies.
TMZIrocZ350
Oct 7, 2015 12:09 PM
