How to stomp a 3.8 Turbo Trans Am ~A Twin Turbo3.4/3.1/2.8?
Old Jun 30, 2001 | 10:33 PM
MrZ28's Avatar
Drop this TwinTurbo 2.8/3.1/3.4 engine in your camaro or firebird .... this is what i want baby :-)
Old Jun 30, 2001 | 10:35 PM
MrZ28's Avatar
oh sorry i forgot a picture hehe..
Old Jun 30, 2001 | 10:36 PM
MrZ28's Avatar
i about get a n** when i see that twin turbo set up.....how sweet it is :-)
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
oh man!!!!!!!!!
i nearly creamed my pants!!!!!!!!
who, what, why, how, how much???????
Old Jun 30, 2001 | 10:43 PM
KED85's Avatar
Details, please.
That is a very tidy installation.
Very tasty, too.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jun 30, 2001 | 10:44 PM
yes, details, i beg of you!!!!!
Old Jun 30, 2001 | 11:08 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
i talked to him when i first got my car..he said the whole thing was nearly 12k..running garrett turbos on s-10 manifolds with the corners cut and flanges welded on. He says he had nearly 600 hp with it
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
Old Jun 30, 2001 | 11:14 PM
uhhhhh 12k u say,
i honestly think i'd rather put that towards my future corvette
Slayer of the following:
2000 saturn
198? Ford Crown Vic, (no i don't know why he bothered)
1990 Buick LeSabre 3.8
1986 Camaro 2.8
Old Jun 30, 2001 | 11:34 PM
yep...ask him... id follow u personally as well.
1989 Firebird
Coming for my v6:
#3 Forever
Old Jul 1, 2001 | 12:05 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
there was a little foreign car on the internet a while back, forgot the name, i think it was a 510 or something, a little beast. anyway, the dude wanted to soup it up, so he took the 60degree v6 and put in there, said the 60* is a well balanced motor, and runs strong, plus they're everywhere (kinda like 305's and 350) but he put twin turbos on it also. but i'd think with 12k you could probably get yourself a turbo 3.8 swapped in. just my opinion. Now, what type of car is that, cause if it didnt' have the 2.8 in there originally, we could be talking cheaper prices, being all we'd need were turbos, wastegates, manifolds, and maybe a different prom... but that's not to much, the turbos would be costly, but of course you could go with the rebuilt route. hmmmm. maybe after college, or during if i can save some cash. lol.
Old Jul 1, 2001 | 12:43 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Sheesh, you don't even bother to post a link....go here to read all about it: http://www.bryanf.com/mycars/510V6.htm
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old Jul 1, 2001 | 01:01 PM
MrZ28's Avatar
i think i might go that route with a 3.4....that is a 2.8 he used so a 3.4 would make way more power. You could actually set up a single turbo powered car instead of a twin turbo one but those twin turbos are sweet. 8.0 to 1 compression is easy to do and like the other guy said you could go find some used turbo's and go the rebuilt route. i think i could do it all for around 2000-3000 dollars and spank some tta's or v8, v10, v12 cars like they were nothing. Its all about what you want to do. Initiative is the main factor i guess.
Old Jul 1, 2001 | 04:34 PM
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
He didn't mentioned too much about the cost of building the engine to take the amount of boost the turbos are pushing out, not to mention little mods to increase flow of the manifold/TBI combo to take advantage. Since I'm in the process of doing the same buildup the cost for the heads/porting and shortblock alone is reaching past the $4000 plateau. The TEC system he's refering to is over $1K. Since he added 2 turbos the price jumps up significantly in addition to the blowoff valves and additional plumbing.
12k dosen't seem to far from real. He didn't mentioned the amount of HP this combo was generating, but making a guess I would say at about 14 PSI it would probably be near 350. But this is without knowing is cam grind, flow statistics, cylinder bore size, etc. I calculated my setup (@14psi)to be 400+. It can be easily boosted to 20+. For those that say "yeah, but for that price I can buy a 'vette' for......", well then buy your vette. But if you happen to be pulling up to a red light next to an unassuming '88 Camaro Sport Coupe, that contains a 3.4L single turbo setup capable of an easy 450+ horses and happens to blow your doors from here to the next intersection, you know what you can do with your 'vette'. Wouldn't it be a challenge to try to explain to your girl friend siting next to you why your $50K Corvette got it's doors blown off by a poor lowly Camaro? Oh and incidently, have you checked the latest prices of what ZR1/L06 go for these days?
Now remember, there is no engine on the road today that sits underneath a hood of an emission legal vehicle that cannot be given a boost of about 6-8 psi, including the 2.8.
Using a single turbo configuration and doing without the TEC, the costs of a turbo install is reduced dramatically. Of course, no insult intended, but projects such as these are not intended to be done by college kids with limited a budget.
[This message has been edited by x55Cam (edited July 01, 2001).]
Old Jul 1, 2001 | 10:47 PM
85f-bird's Avatar
Engine: 2.8L, LS1
you were probably talking about me, and theres no offense taken, more likely than not this would be something that would come farther down the road, cause there's nothing worse than doing a job half assed. But a beauty is that my college as an automotive technician degree and a crapload of computer stuff for cars, including a dynomachine, maybe i could talk to the professors and see if they have any ideas, for a project. heh...university funding wouldn't be bad either.
Old Jul 1, 2001 | 11:01 PM
yup same deal with me......
i am going for auto mechanics 2
my plans are a tad bit simpler
3.4 with raised compression
forged pistons
cam
rockers
porting (maybe)
ram-air
pulleys
MSD
i'm gonna do the engine first
that is, the 3.4 with new pistons, cam and rockers and the rest as i feel like it
Old Jul 2, 2001 | 04:07 PM
Camaro_hunter_d's Avatar
umm why not just get the 4.3 cyclone motor?... it'll take the 3.8... more cubes he he...
Old Jul 2, 2001 | 04:57 PM
MrZ28's Avatar
oh i was thinking about sticking with the 60 degree v6 design so the 90 degree ones might be out of the question.
Evan
AussiePr0nCar
Mar 6, 2020 04:04 PM
bjpotter
Jan 22, 2019 12:27 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
EFR2000
Aug 18, 2015 08:54 PM
