throttle body cooling
Old Jul 9, 2001 | 04:56 AM
nothingssafe's Avatar
Car: 86 TA
i have 2 hoses coming to my throttle body on my 88 2.8. anyone know where to get theses? they have to be molded.
Old Jul 9, 2001 | 08:17 AM
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
GM parts will have them. A suggestion though, since you live in a warm climate area. The reason why coolant passes thru the TB was to warm up the fuel passages under severe cold conditions in the northern regions that cause the TBs to ice up. You can eliminate this 'feature' and save you the hassle of finding these hoses.
Old Jul 9, 2001 | 07:58 PM
Car: 86 TA
so how do eliminate this feature?
Old Jul 10, 2001 | 12:13 AM
KED85's Avatar
I wouldn't.
I didn't.
Engine runs consistant and there is nothing to ever book back up.
This is one time, I didn't remove heat source from air intake.
Go get the hoses from GM dealer.
That's the ONLY PLACE.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jul 10, 2001 | 01:26 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It's easy. Go buy a 12-inch piece of 1/2 inch heater hose; it should cost about $1.00. Then, you remove those TB cooling hoses completely. Link the outlets (from the water pump side) together with the new hose and some hoseclamps, and you're done!
That bypass hose will kink... some guys cut the bypass hose in half, and connect the halves with a small piece of pipe. That "forces" the bypass hose to curve outward, and prevents it from kinking. I've been running with a kinked hose since '97, and have had no problems, so it's up to you.
I think there's a tech article on thirdgen.org that talks about an air-cooled throttle body. The guy did the tb bypass (aka the "!TB" mod), and then ran hose from the TB inlets to underneath the car. He rigged up a funnel on one end (facing foward) to pick up cool air. He then ran the other hose so it pointed "backward" towards the rear bumper. I don't think you'll feel a major gain from that, but it certainly can't hurt, and it's cheap enough to do. Hehe, same thing with the TB bypass; it's cheap, and while you can't feel a power increase, it makes sense to do.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jul 11, 2001 | 08:37 AM
Brian K's Avatar
I have a buddy who lives in Indiana that has done this a few years ago and after several winters it has caused him no problems with it bypassed. Now he does not drive it everyday in the winter only when he needs to when his wife or kids have the other cars, but still it would not be hard to recoonect if needed.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
