Accessory help!!
Old Jun 30, 2011 | 07:59 PM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
Accessory help!!
Hey guys. im in the process of putting my 2.8L after a rebuild and i just now got to it after bout 6 months because of working. and i know dummy me did not take anypictures. why i was wondering if someone could please take some detailed pictures of the idler pulley. if not atleast give me any ideas on how it goes on. any help is greatly appreciated. just want my baby back on the road. thanks guys.
Old Jun 30, 2011 | 08:34 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Accessory help!!
I don't think any of the 2.8s had idlers, mine didn't, and assuming yours has the v-belt setup it shouldn't either, I know the 3.1s were serps and they would have one, but a 2.8 should not AFAIK. If it does have one there would really be only 1 place it would be able to go, and it would probably go on the bottom near the crank pulley, as the alternator and AC if equipped would be at the top.
Old Jun 30, 2011 | 09:34 PM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
the car is an 88 and it has a serp belt. i believe the pulley goes underneath the tensioner pulley next to crank pulley. the car has AC. just trying to remember how that sucker went on. thats the last thing to put on then it can be fired up. i feel soo retarded for not taking pictures. would really really really appreciate it if someone knew more or could take just a couple pics. ive looked at diagrams,scamatics from dealerships but nothing really works. would really really help if someone could. thank you.
Old Jun 30, 2011 | 09:42 PM
Engine: 3.8, 3.4
Is it the tensioner location or belt routing you are hung up on? There's kind of only one way to place the former or route the latter, back side of the belt would run across the tensioner, I would post a pic but I'm away from home and my car. Try google images, can probably find one there.
Old Jun 30, 2011 | 09:48 PM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
its the idler pulley location and how it mounts. if i can just figure that out i have the orginal belt routing diagrahm still on the radiator support. im soo sure it has an idler pulley.... i can swear up and down i took it off and the routing diagram shows it too. im just soo positive it does. my mechanic says soo as well but he cant seem to figure it out either.
Old Jun 30, 2011 | 10:29 PM
Engine: 3.8, 3.4
if it is serp belt it should have a tensioner unless it has adjustable brackets for some of the accessories.
Old Jun 30, 2011 | 10:48 PM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
i know it has a tensioner pulley. its already installed but im saying it has an idler pulley too thats right beneath it next to the water pump.
Old Jun 30, 2011 | 11:25 PM
Engine: 3.8, 3.4
google images...
Old Jul 1, 2011 | 12:22 AM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
i have looked and looked and i can see the pulley. but its all from the front or driverside veiw instead of passenger,which i need. all i need is that one or two pictures....
Old Jul 1, 2011 | 01:32 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
There's a support bar that goes from the back of the idler to the front bottom exhaust manifold bolt. you loosely align the support in place the the Y shaped bracket goes attached to the front of tensioner pulley/alternator bracket and it should line right up with the bolts that it goes to then you just tighten everything down. Remember there's a bolt in the front of the idler pulley that has to be removed in order to go on otherwise it won't fit once it's over the bolts you can put it back on.
Old Jul 5, 2011 | 09:56 PM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
you wouldnt happen to have a picture on the car do you?
Old Jul 5, 2011 | 10:00 PM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
soo you are saying theres a bracket that attaches to the alt/tensioner bracket and the support goes to it and the bolt attaches the pulley,bracket, and bar together?
BDR
Nov 7, 2015 03:05 PM
355tpipickup
Sep 28, 2015 05:50 PM
evilstuie
Sep 24, 2015 02:31 AM
Camaroguy2
Sep 22, 2015 08:22 AM
Mdenz3
Sep 17, 2015 08:36 AM
