Some V6 Options for HP...
Old Jul 10, 2001 | 06:53 PM
Camaro_hunter_d's Avatar
Ok I did some work on my car yesterday. Namely by changing the A.I.R. pump into a vacuum pump. By the way it sucks a good 10 PSI of vacuum...
I took out that free flow PCV to the intake tube and ran 1 inch heater hose into the hole of the valve cover. I took the one way valve off the cat air tube and ran it into the intake line of the air pump. After spending a *hit load of time removing the upper, lower intake just so I could get to the left valve cover and remove it. I am going to run the constant PCV to the left side instead. It will work, the line is clear of all the obstructions so it's a matter of drilling the new hole for it.
It took me about 2 hours to convert the air pump into a vacuum pump and I can most deffinately feel a difference in 2nd,3rd and 4th...
Now a question. I have the upper and middle intake off and plan on polishing them both, inside and out. I want the nice clean shiny aluminum to shine through. What should I use to semi port(gasket match mostly) and polish the intakes????
Old Jul 10, 2001 | 07:06 PM
Brian K's Avatar
Do as I did... I went to home depot and got this bit that cuts aluminum.. It took minutes to perfect and WOW did it rip it quick and smooth...
Old Jul 10, 2001 | 07:12 PM
cool thanks...
Old Jul 10, 2001 | 07:18 PM
KED85's Avatar
It would be more effective to adapt the 3.4 SPI intake to your car.
I really wnated to, but, I couldn't work around the heroin addict that was helping me with the 3.4 swap at his shop. And I had to sell the 3.4 intake to make up the hugh cost out lay for the 3.4 & such.
Was really bummed, I wanted to keep that 3.4 intake!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jul 10, 2001 | 08:01 PM
well right now I don't have the cash so I am working what I have... thanks for the Suggestion though...
Old Jul 10, 2001 | 11:00 PM
3.1 firebird's Avatar
will the 3.4 upper intake mate up to the 2.8/3.1 intake manifold? Are there any flow numbers out there to prove it flows better? thanks.
Old Jul 11, 2001 | 12:32 AM
HIX5000's Avatar
Would the 3.4l intake be a dead give away to the smog police?
Old Jul 11, 2001 | 07:32 AM
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
<font face="Verdana, Arial" size="2">Originally posted by 3.1 firebird:
will the 3.4 upper intake mate up to the 2.8/3.1 intake manifold? Are there any flow numbers out there to prove it flows better? thanks.</font>
Hmmm....I was wondering the same thing. Yesterday my machinest performed a flow bench to the stock intake and heads and I will soon be going over the numbers with him on this. The data will mbe posted on my website. The 3.4L upper intake looks like it flows better but some cutting has to be done to make it fit if you are using a distributor. I would think that there aren't many 3rd gens out there with a 3.4 intake.
Old Jul 11, 2001 | 09:48 AM
KED85's Avatar
The reason why a 3.4 intake can flow better, it is a ONE PIECE DESIGN.
OH YES, the 3.4 is a DEAD GIVE AWAY TO THE SMOG PATROL.
Believe me, they will know!
Can it get past a smog test, I don't know.
My stock 2.8 (even with larger fuel injectors from the 3.4 engine) set up didn't raise an eyebrow and it passed smog.
I won!
I got the powerful 3.4 block under the 2.8 set up!
Chat Soon,
KED85
Karl
Old Jul 11, 2001 | 02:18 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
N/m..only this is the a/c compressor bracket couldnt be used
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
[This message has been edited by Graeme'sFirebird (edited July 11, 2001).]
Old Jul 11, 2001 | 09:55 PM
well I must say that my lower intake(middle I quess?) is starting to look a lot better... Nice clean and shine no crusty a** *hit. I am doing the entire middle top and the sides of it, then to top plenium. I dremel today and I must say that these sanding drums eat through that aluminum like butter...
Old Jul 11, 2001 | 10:40 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I polished my 2.8 upper plenum at
STREET & PERFORMANCE, I work there and use to polish, but now i'm a assistant CNC programer.I took out that crappy 2.8 multi emblem and welded the empty circle in then milled it flat and machined 85 Camaro into it. It looks great except for the the air pockets or as the foundry says gas,that is in the plenum itself,there everywhere on the top of it, but the sides are awesome.The GM foundry must have had a sand problems in their molds when they poured the aluminum.
Old Jul 11, 2001 | 11:05 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Does anybody have a pic of the 3.4 L intake??????
Old Jul 13, 2001 | 11:21 PM
well the middle and upper intakes look much better... I am going to gasket match tommarrow and then out it back togeather... Hopefully it'll light up...
Though I got another turbo book the other day and finally got around to looking at it. It had an article where they took an 85/86? SVO mustang turbo and out it on a 4 banger(I know rice but listen) the engine picked up 75HP without an intercooler! on 6 PSI!. And the torque matched the increase. Now to just have the headers made... Oh well tubing bender here I come!... And I have toi but some steel plate to make a few mounting brackets too... have to relocate a few things.
Old Jul 16, 2001 | 12:08 AM
Well I got it all put back togeather today to find a leaking O-ring... Oh well. I went ahead and polished the 2 A/C brackets and the tops of the plenium bolts they look like black chrome almost. I painted over the intire thing including the brackets with clear gloss paint to keep the steel parts from rusting. Well the plenium looks great, now the throttle body looks way outta place cause it's still cast... Oh well you can't win 'em all right?. I will try to take pics and post them.
Old Jul 16, 2001 | 05:33 PM
well I got the O ring replaced and took it for a spin. Man the difference in 3rd&4th are amazing. Pulls alot more now above 2k. I had a pesky 88-90 F150 tring to race me today on a back road(doing 55-60) so I dropped into 3rd and gunned it and before I knew I shifted into 4th and was doing 95 close to 100... hit 5th and it still pulled... but then the damn gov was staring at me and I let off, he backed off after that.
Old Jul 16, 2001 | 06:15 PM
91FIREBIRDGT's Avatar
Car: 1991 Firebird
Engine: 3.1LV6
I know that some of you guys might hate me for this but I got the chrome intake look for my car. I used a 96-99 civic intake, K&N conical air filter and a j-bent pipe. I connected the j-bent pipe to the throttle body then connected the civic intake to that followed by the filter. i connected the vacumm line from the valve cover to one of the side outlets of the intake piping, and i connected the air intake temp. sensor to another outlet. For the temp. sensor you may have to get a sensor relocation kit. It all fits nice and snug. all i need to do is to make a hole in the metal underneath where the stock filter box was sitting on to make it into a cold air intake.
1991 Pontiac Firebird V6 W68
Pioneer DEH-7000R, Pioneer 6X9 4way/4X6 2way speakers, MTX 250watt amp, MTX 400watt sub, custom intake, Flowmaster dual exhaust 80 series, PIAA HID headlamp conversions, custom tail lamps(regular F-bird but amber is now red), many more to list...
Old Jul 16, 2001 | 06:37 PM
take a pic of that!
1989 Firebird
Coming for my v6:
#3 Forever
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
