tranny swapping
Old Jul 17, 2001 | 07:23 PM
Little E's Avatar
tranny swapping
Going to do swap my automatic tranny for the manual. I have already located the v-6 tranny and almost everything to go with. Will the rearend be affected with this? How about the speedo? Also the tranny is missing the shifter, would it be better to spend the extra doe and get a short throw shifter or is a stock replacement just fine. How long can i expect to take to complete. Thanx for the help.
Old Jul 17, 2001 | 07:42 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
It took me nearly 2 months because i wanted everything done right the first time.. get that short throw, the stock sucks i know i have it. The speedo shouldnt be affected, but it depends if u have an electronic or cable driven. if u have an electronic now, make sure the new one has vss on it, or take out the old cable drive and put in a driven gear and VSS..same goes the opposite way. no, no problems with rear...except the torque arm..i couldnt find a mount that worked correctly so i kinda fabbed something up until i get a spohn torque arm..
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
Old Jul 17, 2001 | 08:15 PM
Brian K's Avatar
Is it really worth the change to stick.. I plan to run NOS and I know one day my 86 tranny will need a rebuild again, so I have pondered the idea. My only problem is I havea hurst dual gate shifter and it looks so cool.
Old Jul 17, 2001 | 08:31 PM
Hmm...ya know, i would have probably been better off and cheaper to have just taken out my convertor and gone to a high stall converter... but i dunno...
1989 Firebird
Coming for my v6:
#3 Forever
Old Jul 17, 2001 | 10:15 PM
Little E's Avatar
What does the torque arm have to do with changing the tranny? Actually i'm not sure what the torque arm does.
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
