FAN SETUP Question
Old Jul 21, 2001 | 12:53 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
FAN SETUP Question
Ok I'm going to be wiring up a fan switch on my 3.1L V6, My setup is going to involve the wire that goes from the Fan relay to the ECM. The way it works on my car is the ECM grounds the FAN relay to Run the fan. I want to add a 2nd Grond using a wire and a switch to ground the fan relay in front of the ECM but leave the ECM connect so that it can ground the FAN for the A/C. My question is will this hurt the computer and will it work.
Old Jul 21, 2001 | 01:03 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
do a search... it was explained to me about 2 weeks ago.
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
Old Jul 22, 2001 | 11:14 PM
I don't need it explained just want to know if grounding it ahead of the computer will hurt the computer any,,,, I say no but want to get a 2nd opionion.
Terrell351
Jun 13, 2021 01:13 PM
beastin91rs
Oct 9, 2015 07:38 AM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
Leggman1
Aug 6, 2015 04:15 AM
