weird clunk in rear when I let off the gas
Old Jul 31, 2001 | 11:46 PM
red90rs's Avatar
when I let off the gas at most spoeeds i get a clunk. also when I hammer it from a stop or out it in gera theres a thump too, but I dont know if theyre related. I pretty sure the shifting in gear clunk is the u joints , but I"m not sure on that either.
thanks,
Derek Johsnon
90 red rs 3.1 Mods--hypertech thermomaster chip, 160 degree thermostat, and K&N filter
Soon coming: compucam 3020, 1.52 rocker arms, 3.73 posi, and msd 6a
I Live my life a quarter mile at a time(the fast in the furious), only it takes me like 18 seconds to do it in this v6!!!
Old Aug 1, 2001 | 12:13 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Your right, it's just the drive shaft slack tighting up, I get that some times when I'm in over drive and i let off the gas then push it back down again.
Old Aug 1, 2001 | 01:51 AM
xtremelegend's Avatar
Check your transmission mount
Old Aug 1, 2001 | 07:05 AM
Brian K's Avatar
Sounds like the tranny mount. Also, this is post 1000 for me!!!!! I have broken a barrier.
Old Aug 1, 2001 | 09:18 AM
Ovrclck350's Avatar
A shameless 1000'th post plug? How funny. j/k. Mine was better. I had an entire post dedicated to it.
Old Aug 1, 2001 | 12:53 PM
SAEspinz80's Avatar
i dunno, when my mount went i didn't hear it from the rear. i heard it during hard shifts and it sounded like it was coming right out from under the shirter...or even more up front the the passenger side floor pan. but you can check it anyway. i also for a whole heard a clunk coming from the rear of my car when i would go over pot holes or bumps. then my dad and i found it when we were rotating my tires. if you remove the back tire and looke behind the the drum there is this thing that looks like and elongated bolt with rubber stoppers on it. well, mine rusted out and snapped loosing the stoppers and creating a thump when the axle would move. dunno if this is it, but it was a cheap fix..like 3.00...and its easy to look for. there is a diagram of it in the chiltons manual too, i can look up the name of the part tonight...
1990 Firebird 3.1
- Auto Trans, TA Body Kit
- Home Made C.A.I.
- ASP Underdrive Pulleys
- MSD 8.5mm Superconducter Wires (custom-cut)
- MSD GM Blaster Coil
- AC Delco Cap & Rotor
- Bosh Platinum +4 plugs
- Mobil 1 Synthetic Fluids
- 2.5" Hooker Aero-Chamber Cat-back
- 2.5" Hooker Elite Stainless Extension Tips
- GTS Blackouts (stickers removed)
- TB Bypass
KILLS = Dodge Daytona (stick), 2000 Toyota 4 Runner 4WD,
1997ish Ford Explorer, "older" Jeep Cherokee (don't ask why they are all SUVs...who the hell knows?)
LOSSES = 300zx (had him half way through 2nd, he was manual)
"The racing dice added 5hp...I SWEAR!"
Old Aug 1, 2001 | 01:04 PM
sgtpanther's Avatar
Mine is doing the same thing....I thought it was coming from the rear...but it is my tranny mount...check there first.
Old Aug 2, 2001 | 01:40 AM
88-RSport's Avatar
Mine did that too. It turned out to be the engine mount, when I would give it gas th torque would lift the engine from one side then in would drop back down, and make a thumb near the center console. It also F***ed up my tranny.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
EFR2000
Aug 18, 2015 08:54 PM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
