3.1l turbo questions///
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Ok i am very serious about putting a turbo on my car but can only buy some stuff at a time... ya know.. like buy the turbo one week then in a few weeks buy the piping and so forth. Ok well are one of the ebay turbos I have Linked on this page a decent turbo to buy? Im not sure which is better. Such as an internal wastegate or external. Also, I only wish to get this 3.1L it like 230-250Hp at most. Car has 106K on it. Any advice on turbo sizes and such is greatly appreciated! Hell with the nitrous! I was going to do that but for just a little more $$ and time and effort I know I can get at turbo on my car succesfully!
Here are a few Ebay ones...
http://cgi.ebay.com/ebaymotors/T04E-...Q5fAccessories
http://cgi.ebay.com/ebaymotors/T3-T4...Q5fAccessories
Re: 3.1l turbo questions///
but the stuff seperatly it helps save a lil bit of money.
let me link u to a few guys i just bought a bunch of stuff off of
the right turbo
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
88 bucks + 21 shipping
8 psi wastegate
45 + 10 shipping
downpipe flange
8.50+5.50 shipping
inlet flange
9.99+5.50 shipping
the guy with the flanges will combine shipping on the set
i just bought 2 of everything from these guys so i can vouch for them and they ship fast as hell
the right turbo
8 psi wastegate
45 + 10 shipping
downpipe flange
8.50+5.50 shipping
inlet flange
9.99+5.50 shipping
http://cgi.ebay.com/32X12X3-UNIVERSA...item35b1e4e0a1
185 shipped
i dont recomend this intercooler for firebirds
185 shipped
Car: 1991 Camaro RS
awsome thanks for the links.... Project 89----Do you think my injectors will support 7-8 psi??
btw the turbo i lnked u to is a lil larger then the other ebay turbos heres a pic of them mocked up on my iroc
have to clock the housings
Transmission: 5-speed/T-5
I will agree that I was running that at or beyond 100% DC, but they worked for me for over 2 years.
Car: 1991 Camaro RS
i have the stock engine. stock injectors.. there 19# right?? So what should i look for size wise. Like #22 or #24??? Do you think the stock fuel pump will be ok with the larger injectors?? If it matters i just replaced it one year ago. Thanks again for the help!!!
Car: 1991 Camaro RS
on pilsburys car we installed 48# injectors.
i would go for a set of 32/34# injectors, ur going to have to tune the car anyway might as well leave ur self room to grow. if u look around on ebay or even most aftermarket places 32/34's will cost only slightly more then 24's
Car: 1991 Camaro RS
ok ill look at the #32 or #34 injectors then... I bought the turbo that you linked, a few mins ago! Ill be here in a few days but ill have to wait till next friday to buy more..slowly but surely ill have it all. Are the injectors diffenent in different cars? Or can i just look for #32 injectors? Oh ya Im going to do everything myself but the to tune my comp. so what it a fair rate for someone to do the tune for me? Thanks again!
Yes there are different types of injectors.
You will want O-ring style injectors, 14mm IIRC. You could also use "Multec 1 style." Pretty much anything that will fit in a 5.0L Mustang, TPI F-body, and a few other cars will work.
Car: 1991 Camaro RS
ok thanks for the info on the injectors...project89 and six shooter.
what about a tune.... how much is that roughtly??? Im on a budget or i would set up the comp. so i could tune it myself.
if it was me id be doing a ms1 v2.2 for 311 bucks or a ms 1 v3 for slightly mmore
Car: 1991 Camaro RS
There is a place called Busher Racing near where I live an Im sure they tune cars. Ill call them since there only 10 miles away. Im on a tight budget and I will look into burning my own programs once i can afford the $$ for the system. Ill look into the tuning part on thirdgen.org and see what i can learn. Im a total beginner when it comes to comps. on cars. Im use to working on cars without them.
Car: 1991 Camaro RS
actually could you send me a link for the megasquirt you have???
this is the one on my v6 car
http://www.diyautotune.com/catalog/m...unit-p-34.html
252 bucks + 65 for a harness
the one on pilsburys car
http://www.diyautotune.com/catalog/m...unit-p-56.html
346+65
and this is the one on my tt iroc
http://www.diyautotune.com/catalog/m...unit-p-65.html
420 bucks + 65 for harness
346+65
Car: 1991 Camaro RS
am i looking for something like this to burn the chip myself??? Thanks!!!
I saw some that were not assembled..they were less$$...But that looks like a pain to assemble the thing.
Car: 1991 Camaro RS
ok i got the link but what about the programs... are they downloadable on the net or do i just have to make my own??? Ill read more on the tuning before i ask anymore questions since im so new at this but thanks a ton for the links!!!
if u buy the kit that u have to solder urself its not that bad but the extra 100 bucks to buy one preassembled and tested is well worth the money spent
http://www.diyautotune.com/softwarelinks.htm
Car: 1991 Camaro RS
ok thanks again for the link... my turbo should be here by friday but itll be about a month before i get every thing together for the project... i read some more and i think i understand how to tune the car. The last question about the turbo is what is the best route for the inlet exhaust on the turbo and the down pipe? SOme pictures are hard to see what really was done. Would it be easiest to make a log type header for the inlet exhaust then just run the down pipe into the y collector>>
look at the header design i did on pilsburys car thats going to be the best and simplest way to do it.
just build the log on the passenger side and reuse the stock manifld on the driver side and make ur own crossover pipe to cnnect the 2
the downpipe will just go out to the factory cat location were u would be unbolting the stock y pipe
Car: 1991 Camaro RS
ok i checked his pics out. Im going to attempt to build on over the weekend. Thanks....if i have more questions can i just pm you? Although it might take me a month to get the system together, there will be another turbo v6 on a third gen.
For info on tuning the stock ECM, or other GM ECMs that might be more suitable (The 1227730/1227749 comes to mind running code $58 or code $59), check the DIY PROM forum on this site.
Car: 1991 Camaro RS
am i going to need a 2 bar MAP sensor for the turbo too??/ I heard that I may need one but i dont know if the guy knows what hes talking about.
yeah pm me anytime, if u stick with the stock ecm u will need to upgrade the map sensor
Some code will only use a 1 BAR, but wouldn't be very turbo friendly, and other parts would have to be used to add the proper amount of fuel and control timing.
Some code uses a 2 BAR MAP, such as code $58 (Syclone/Typhoon/Turbo Sunbird), code $8F (Turbo Grand Prix).
Some code uses a 3 BAR, such as code $59, which is an updated and modified version of code $58. (www.code59.org)
Car: 1991 Camaro RS
ok thanks again for all the tips.. the turbo has arived.. and i just have to wait to get paid again next friday so i can buy more.... attempting to make a log header pipe tommorow...
word of advice take the turbine and compressor housings off and blow them out or wash them in hot soapy water, if u wash the turbine housing spray it with some hi temp grill paint so it dont rust up on u.
the only bad thing i found with mine was some metal shavings from when they tappedthe holes for the downpipe flange
Car: 1991 Camaro RS
Now have turbo, megaquirt, and i am still fabing up the log style manifold. As i start this project ill post many pictures.
Car: 1991 Camaro RS
So far I have the turbo, megasquirt, intercooler and piping, BOV, and im still working on the manifold piping. I hope to have all the parts by the end of the month. Ill put up pics and probly questions then. Thanks for all the advice! Im sure ill have questions once i start to put it all together.
pics ???? how many blades on the turbo u got
Car: 1991 Camaro RS
6 blade.. its a .50 compressor/.63 turbine.. ill put pics on this weekend when im playing in the garage. Im hoping this can give me 220hp or so at a low psi. like 7-8psi. Since its a smaller turbo won't it spool up faster???
did u buy the same one i did? it should have 8 blades
Car: 1991 Camaro RS
This is the one i got.....the pic is crappy but it gives you an idea of what it is. Ill put up pics of all the stuff this weekend when im not working.
ahh ok u bought a different turbo, its a 48 trim t3/t4 they work pretty well on the v6
that design of the turbo spools up better then the one i originally used on my car, pilsbury has the same turbo minus the antisurge housing. the antisurge will make it spool a tiny bit slower but its a good turbo
Car: 1991 Camaro RS
ill keep ya posted as the project begins, I ended up getting the PBC2.2 megasquirt too. Im sure thats gonna take some time for me to learn all that it can do.
pilsburys base ignition and fuel tables will get u up and runnin in no time, they will make the car run slihtly rich since he has a 3.4
Car: 1991 Camaro RS
well rich is better than lean... i dont wanna burn the 3.1L up... Once i get it all together Ill ask him for the tables.
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
they are posted on my turbo thread
heya pils that 88$ turbo i posted up earlier in this thread is a cheap but good upgrade to the turbo u have, besides allowing for more max hp its also more efficent. its also a bolt in replacement for the one u have
turbo u have now measures 49/50mm the 88$ one = 57mm
I'm a long way out from getting an upgrade. I actually don't see the car moving out of garage this year
