wont start, no check engine light (after 3.4 swap)
Old Aug 21, 2001 | 09:01 PM
mrzud's Avatar
Ok, I just got done doing a 3.4 swap in my 89 RS , got it to run, fixed timing, and everything was fine; when the car wasnt moving just running. I pulled out of the garage and stoped at the end of the driveway to turn and it just died. We pushed it back into the garage and checked it out. When we turn the key to the on position the "Check Engine" light does not come on and there is not the normal wail of the fuel pump nor the fan, nothing happend out of many times trying. I consulted Haynes and Chilton manual but found nothing. Family and friends clueless. What happend? I need YOUR help, if you can.
Thanks,
Adam
Old Aug 21, 2001 | 09:42 PM
KED85's Avatar
GREAT GOING YOU GOT THAT FAR!!
All I can suggest is to check all electrical connections.
You have a loose ground connection going on.
I'll make ya feel good.
Did a complete rebuild on my Motorcycle. Got the engine in etc.
Couldn't get it to run
Gave it to Honda ($350) to get it to run.
Got it to run.
The built engine had an oiling problem. It died (ruined cam!!). I swapped in another engine. Got it to run. It keeps stalling. (I would push it back a 1/4 mile to the shop) Trying to find the electrical short that kills motor. Thought I had it. Ready for another try. Then discover I have a flat rear tire!
Next weekend.
Look at all grounds etc. One is flaky.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Aug 23, 2001 | 08:44 AM
mrzud's Avatar
well, i checked all the gounds and they seem fine. I also checked the connections that we messed with while doing the swap, also ok.
Any other suggestions?
Old Aug 23, 2001 | 09:13 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Have not looked for any on my car, but what about fusable links? if the right one goes, ou can shut the entire car down
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
