Need the experianced
Old Aug 18, 2001 | 07:02 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Heres what I got 2.8 bone stock.Heres my problem,when I turn the key to the pos before on,the fuel pump doesnt shut off when the pressure builds up.Second when I crank the motor the fuel pump relay buzzes like He!!,and the motor doesnt turn over too.
Old Aug 23, 2001 | 12:30 AM
Camaro_hunter_d's Avatar
well if the car does not turn over go through the stuff that it can be. Not too much to check, just batt and starter. The fuel pump thing may be a bad sensor.
Old Aug 23, 2001 | 08:35 AM
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
Sounds like you have a fuel leak or the fuel regualtor is 'open'. The pump is supposed to stop pumping once back pressure builds to a certain level that is controlled by the regulator, that the pump is designed to detect. While the engine is running the pump will allways 'buzz' since fuel demand is allways there, which causes the pump to keep pumping. If you hear it constantly that probably means fuel is either leaking out or returning to the tank.
Old Aug 23, 2001 | 12:01 PM
IROC5.7TPI's Avatar
Sounds like a sticking FP relay to me.
They're only >$10. Replace it and see if it stops.
They are known to stick on.
Old Aug 23, 2001 | 08:01 PM
Car: 85 Camaro SC
Engine: V6
I figured out what happened.A wrench had fallen on the battery treminals and shorted it out.When i was trying to use a recharger to get things going it didnt have enough juice to crank the motor over and the all the relays on the driver side would buzz like crazy.Luckly when the wrench fell on the bat the + & - cables were not attached.
But thanks for the help guys.
Old Aug 23, 2001 | 08:07 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
and the bat didn't blow up
Old Aug 24, 2001 | 08:38 AM
x55Cam's Avatar
Engine: 5.7L
This is a perfect example of why I take these posts with a grain of salt when they explain in some obscure manner that the car is acting strange and later you get the usual 'I found out what the problem was...' that is so far out of the ordinary that you just shake your head and wonder.
antman89iroc
Jul 23, 2014 07:50 PM
fleshead
Jun 7, 2013 04:28 PM
gregl316
Apr 23, 2012 06:31 AM
Stevo
Aug 5, 2006 07:53 PM
IROC HeRbZ
Feb 19, 2006 09:12 AM
