for u guys porting and polishing ur own heads.
Old Aug 23, 2001 | 11:02 PM
grouper's Avatar
i found this the other day and there is some really good info. Its not really to hard of a job if u keep it basic and take your time. make sure u get soem spare heads so u dont run the risk of junking whats on your car, i snaged a set of 2.8 heads for 20 bucks a pop jsut to practice
www.sa-motorsports.com/diyguide.shtm
Old Aug 24, 2001 | 12:22 AM
3.1 firebird's Avatar
porting heads IS easy! I just ported a spare set of 3.1 L heads with my dremel .Best of all it only took about an hour or so per head.
heres what I did:
1.intake gasket match. Just take the gasket that goes between your intake manifold and head, lay it on the head properly then scribe a line folling the opening on the gasket. Now take your dremel and grind out to the lines youer scribed. Just blend then ground out area into the port about 1/2 of an inch and you are done.
2 smooth the intake and exhaust valve guide bosses to look like a "tear drop". Try not to nick the valve seat though. The exhaust sides are worse.
3. where the short side radius comes to the valve seat there is a hard ridge, just smooth it over.
Old Aug 24, 2001 | 12:30 AM
WaynesRS's Avatar
THIS IS AWESOME GUYS , I was just thinking about this the other day , and was thinking about it lastnight when I went to bed.THANX FOR THE LINK GROUPER , WAYNE
Old Aug 24, 2001 | 09:18 PM
oh I forgot to add, you can Polish the coombustion chambers to amirror shine, but I dont think there is much to gain here. If you enlarge the chambers to much you lose compression, so I didnt bother with it.
DONT polish the intake ports, leave them rough because the fuel need some turbulance to help it mix with the air.
YOU can mirror shine polish the exhaust ports.
I;ve read a couple books on this stuff, so dont think I;m trying to be a know-it-all or something like that.
Old Aug 24, 2001 | 09:35 PM
WaynesRS's Avatar
Its cool 3.1firebird , Thanx for all the useful info cus i do want to do this before long .
Old Aug 24, 2001 | 10:56 PM
wayne, get the book "how to build horsepower". It tells all the details. I think there is a faq on the net somewhere that actually has pictures on how to do it.
Old Aug 25, 2001 | 12:41 AM
KED85's Avatar
That's the way I learned, looked at pics, asked a knowledgable person got some polishing ginding stones and had patience.
It is simple in execution.
BUT, as David pointed out, you need to have some guidence.
Before ya do this, keep reading, looking at pics, ask. WATCH SOMEONE DO IT, give 'em a six pack for the quick lessons.
ONE of the best tips, always work with good lighting on the subject.
Keep trying to find videos about this subject to watch, also.
Go to wrecking yards for your subjects to grind on, also. It's cheaper!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Aug 25, 2001 | 02:08 AM
Camaro_hunter_d's Avatar
Yeah standard abrasives are great people to deal with. They'll tell ya how to do anything you ask (that is within reason and there knowlage!)
86IROC112
Aug 17, 2015 02:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
89-S-dime
Aug 12, 2015 11:57 AM
Jake_92RS
Aug 11, 2015 10:39 AM
mx127
Aug 10, 2015 08:13 AM
