Defferential's guts
Old Aug 30, 2001 | 02:04 AM
mAjInRS's Avatar
Defferential's guts
ok, i've already had my rearend replaced so i kept the old one so i could stick some new gears in it and convert it to disc, the first problem i have already run into is getting the damn old gears out, good thing i replaced it when i did(looks like i didnt have to invest in a second opinion after all Karl) when i took the differential cover off and drained the oil out of it i noticed there where big chunks of teeth missing off the gears, and i found seven or eight of them in the bottom of the drain pan, the problem i am having is getting the gears out of the damn thing, i've already takin off the bolt from the driveshaft end and it seems like the thing is connected all the way through, does anybody know how to remove these gears i'd really appreciate it. TIA
91 Blue RS with ASCD SS hood w/hood pins, Flowmaster 80 series, K&N, Bosch Platinum wires and plugs, rebuilt transmission with shift kit.
Soon to be added:
Z28 spoiler.
New paint.(black with orange stripes)
A 3.4L V6.(WOOHOO!!)
Official Kills:
80something Monte Carlo SS
New Civic
Ford Splash(Souped up somehow, he was chirpin every shift)
Late 90's Crustang
Early 90's Crustang(at the strip)
Older Eclipse(at the strip)
CRX(at the strip)
Old Aug 30, 2001 | 09:35 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Did you remove the axles already????
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-Currently collecting parts for T5 swap
Old Aug 30, 2001 | 11:54 AM
KED85's Avatar
Yu take the bolt out to remove the shaft.
Rotate unit until you see the bolt.
NOW, push in the axles, 1 ata time, you see the "C" clip, remove with a magnet! Axle slides out.
BUT setting up the other gears, take tools & talent.
That detail is up to others.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Aug 30, 2001 | 03:12 PM
mAjInRS's Avatar
ok, your gonna have to simplify this a wee bit more for me, what do you mean by the "axles" sorry but i just wanna be completly sure before i screw something up, its my first time...
Old Aug 30, 2001 | 03:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
A magnet? Damn, good idea! When I rebuilt my axle, I was trying needle-nose pliers!
The axles (aka "axleshafts") are the things that the wheel bolts onto; they extend into the axle housing, and meet at the differential (open or posi). There's a little bolt (8mm I think?) that holds in a lock-pin... you remove the lock pin, and the axleshafts slide out of the differential a bit. Then you pull the c-clips out, and then pull the axleshafts out. While they're out, it's a good time to replace the axleshaft bearings & seals. Are you doing the gears yourself?
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Aug 30, 2001 | 03:25 PM
mAjInRS's Avatar
ya i'm wanting to do them by myself so i can gain the experience and stuff like that, sorry to ask but do you have or know where i can get an illustration for this?? and does anybody know where i can get the 3.73 gears for this swap?
[This message has been edited by mAjInRS (edited August 30, 2001).]
Old Aug 31, 2001 | 01:26 AM
mAjInRS's Avatar
come on guys.....
Old Aug 31, 2001 | 09:37 AM
KED85's Avatar
Don't laugh & the gears may be noisy, but 4 cylinder S-10 Trucks.
Same thing.
I got my education from news stand magazines. I have several dozen articles. & Pictures.
Go to a book store & check out the Hot Rod book section. May find a book about rear axles, there.
Library, too!
On-line, there's got to be some info to assist ya!!
Or go to a garage and ask.
Chat Soon,
KED85
Karl
Old Aug 31, 2001 | 02:17 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My 82-92 Haynes book tells how to remove the axleshafts, and replace/install the rear axleshaft bearings & seals, and change the rear fluid, and change the rear brake hoses/e-brake cables.
Summit Racing sells a video, by Richmond, on how to set up gears. They also sell an installation kit, with gaskets, shims, marking paint, etc. You'll need a dial indicator & stand, and I believe you need a special torque wrench, too. Be careful with the gear set-up; if it's not done properly, you can destroy the gears with one drive. It's not a "pull-old-install-new" swap.
As per Karl's advice, if the truck has "GT4" on the options sheet in the glovebox, that means 3.73 gears. You can get new gears for $200, so if the junkyard wants $150, tell them what they can do with the gears.
Jeremys87
Jul 14, 2022 09:08 PM
L98FORM89
Aftermarket Product Review
Jun 27, 2001 07:27 PM
Dellz
Oct 30, 2000 05:39 PM
