Power Loss Adding 2030 Cam HELP!!!!
Old Sep 14, 2001 | 02:06 PM
Jaren Bon Jovi's Avatar
I have a 1992 3.1 automatic firebird with 51,000 summer miles. Stage one of my modifications were as follows: hypertech thermo chip, home made K&N cold air, MSD 6A ignition, Jet power pulleys, and a dynomax exhuast. With all of that I was able to beat my brothers 92 RS 5.0 TBI automatic with only 46,000 summer miles.Then I wanted more so I put Cranes 2030 cam, and 1.52 roller rockers by comp cams. I let the cam break in and then I raced my brother. I LOST!!!! How can this happen, please tell me that something can be adjusted I need answers I really would appreciate some help. I spent 2,000 bones to go slower. My friends, take it from some one who put the cam in, dont do it!!
Old Sep 14, 2001 | 02:09 PM
AntiVTEC's Avatar
Thats really odd. Did you pull the motor out to do the swap? You might have broken some vacumm lines in the process. Also, make sure you reset the comp and drive around to get it used to it.
Most guys on this board who've done the cam hit about a second faster than those who havnt.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro, ~68 Chevelle 350, 92 CRX Si.
Old Sep 14, 2001 | 02:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I assume you put the cam sprocket "straight up"; and didn't retard or advance valve timing? Did you use a new timing chain? Did you give the rockers the proper preload (set lifters to zero lash, then add a 90 degree turn to the rocker arm nut)? Are you letting the trans shift on it's own, and if you are, what RPM does the trans shift at?
Did you re-use all the upper intake gaskets, and injector o-rings, or did you replace with new? Did you reset the TV cable? What is your ignition timing set to? How's the fuel pressure?
Does the car feel more powerful after the cam swap, and it's only the race that doesn't show it? And the $2000... you don't just mean the cam, right?!?
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Sep 15, 2001 | 12:10 AM
rezinn's Avatar
two thousand dollars?! what?!
Old Sep 15, 2001 | 01:46 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
My Guesses:
Cam installed wrong, Lash on rockers not properly set, cam for wrong engine.
Any idling problems? Whats gas mileage? anything else happening besides being slower? what about timing chain? Did you pull the distributor to make sure the teeth werent bent or anything when they put the cam in? BTW... $2000?!?!
1989 Firebird. Modded.
700r4-->t5 w/ram clutch
Cold air, 1.6 rockers, 21lb injectors, 3" y-pipe, random tech cat, 3" ipipe, flowmaster 80 series 3" in 3" out hand made stainless tips, Lakewood LCA's, Msd 6a, Msd coil, Wonder Bar, 180* stat,
First 1500 bucks gets the car..runs great. no problems. needs paint.
http://www.geocities.com/graemeg1984/New.html
rather run last in a full out race, than to NOT have run at all"
See my car Here!
In Memory of #3 Dale Earnhardt
Old Sep 15, 2001 | 11:02 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Im sure he means 2k total all the parts/labor.
Yea check everthing out mentioned above, one of them should be the problem, I doubt you lost because of wheelspin from too much power
SSC
theshackle
Sep 17, 2020 08:26 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
Bradsaundry
Aug 12, 2015 12:34 AM
slade5612
Aug 11, 2015 07:19 PM
