Should the coolant temp idiot light come on when the key is in 'on' position?
Old Sep 27, 2001 | 08:01 PM
Xenodrgn's Avatar
Everything else comes on, oil, batt, and check engine, just not the coolant temp light... is it supposed to do that?
It comes on when it's put into the 'start' position however.... it just seemed odd to me that everything but that would come on...
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Sep 27, 2001 | 08:35 PM
OneTireFire's Avatar
Yeah....they are all suppose to turn "on" when the key is in the on position...but when you start your vehicle they should all turn off.
Old Sep 27, 2001 | 08:46 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
does that apply to all 2.8 engines? on mine only thing that comes up on start up is my seat belt and e-brake lights...
Time has come... i bought a nova.. so its time to sell the firebird.
http://cgi.ebay.com/ebaymotors/aw-cg...item=595764164
I'd rather run last in a full out race, than to NOT have run at all"
See my car Here!
In Memory of #3 Dale Earnhardt
Old Sep 27, 2001 | 08:48 PM
Xenodrgn's Avatar
Oh damn... Lemme rephrase:
What about cranking, what should the lights do while the engine is cranking? Right now, when the key is in the 'on' (but not running) position, everything but the CT light is on, but when I crank, it comes on along with the rest. Once the key returns to the 'on' position (with engine running), they all go off. Is something up here?
From what you're telling me I assume I need a new CTS... do I need to drain the coolant first? This may be the perfect time to do the TB bypass mod -and- flush my coolant system for the year (I'm sure it's never been done).
Is there some sort of relay I should check for the CTS first?
Old Sep 27, 2001 | 08:50 PM
Xenodrgn's Avatar
Graeme, I don't know, I don't think every year/model is the same... my e-brake light doesn't come on in the 'on' (off) position, I don't know about cranking, I'll pay attention tomorrow morning.
C'mon, spin 'em for papa...
Old Sep 27, 2001 | 08:51 PM
Yes..typically all dummy lights are suppose 2 come on when the key is in the on position....however i've seen alot of camaro's with dummy lights that don't come on....must be a common problem.
One light that you have 2 make sure that comes on when your key on the on position is the check engine light.
When you get your car smog tested...the technician will turn the key on, if the check engine light doesn't come on, you will pass smog.
He does this 2 make sure that you haven't disconnected the bult of took it out.
Your check engine light should come on when the key is on. But when you start your vehicle it should turn off!!!
Bad A$$ Boys Drive Bad A$$ Toys
Old Sep 27, 2001 | 08:55 PM
Xenodrgn's Avatar
Onetirefire, yep, it comes on, and then goes off once it's running...
PS, graeme, just read about the 'bird... it's sad to see it go, especially you, I've valued your opinions and suggestions over the course of my stay. Are you still going to hang here? Do you still have another thirdgen? Good luck in the future, and with the Nova.
Old Sep 27, 2001 | 08:56 PM
Sorry about that.......I replied to the wrong post...bye-bye
Old Sep 27, 2001 | 09:50 PM
Nope, no more thirdgen But, i will however still be on the board to answer the questions that i can
I wouldnt know as much about cars if it wasnt for this board, so i hope to help some people out!
See my car Here!
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
Omega
Aug 10, 2015 12:46 PM
