What speed does everyone idle?
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
I notice my car idles around 750 but at certain times it drops to below 500 and then jumps back. I want to know this because I'm not sure if this is right.
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
New Pioneer Head Unit
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
yep 750 is right, if your idle is dropping below 500 and then bouncing back up to 800 when you do hard stops with the A/C on then you need a new IAC because yours is sluggish and it's not opening fast enough. Believe me it happen to me, I didn't see the worning signs then DEATH, everytime I hit the brakes in traffic it would die.
Car: 1992 RS
Engine: 3.1L V6
Hey! Mine does that too! It usually sits at around 750 and sometimes it will drop down to the 500 and sometimes die! It sucks! I still want to know what causes this. And it's not when I stop, sometimes you just start up the car and it can't hold the idle high enough.
1992 RS 3.1L Bone Stock
"Yeah, it's a V6 SO WHAT!?"
800-900 with my 5-speed.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro.
i dotn friggin know because my 2.8 didn't even come with a friggin tach...
1987 V6 MPFI Camaro SC with a white exterior and a red interior, get more info and a few pics of my ride by clicking here:
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=4760
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
500-550 RPM. Auto.
89 RS
STILL Looking For:
An 87 IROC-Z28 350 TPI
89 RS
STILL Looking For:
U see in my sig it says 89 RS?? Thats a 2.8 dude.
89 RS
STILL Looking For:
89 RS
STILL Looking For:
My 92 RS 3.2L w/5speed idles at the 10 mark. It would somtimes dip and the engine would die. Afterwards I couldn't start it for about 10 min. So this last weekend I swaped the ECM and life is back to normal no diping idle, but still at the 10mark.
Car: 1986 Firebird
Engine: 2.8 V6
87Camaro, throw one on! It's not hard at all... the hardest part is leading the tach wires thru the firewall- you'll probably have to drill. Drill from underneath the dash "out" to the engine compartment. You might get lucky and have a factory "plug" in the firewall- knock it out with a punch. The plug's located to the driver's side of the brake booster on the firewall. The next hardest part is finding a spot to mount the tach where it looks good (and can be read easily). Hookup is simple. Your car's tach wire is the black/white wire on the gray connector on your spark coil.
-Tom P (Hot rodded 1986 Firebird 2.8l)
From: First one out of liberty city, burn it to the ground
my car used to idle anywhere from 1200 to 400..now its idling right at 800...
1989 Firebird. Modded.
700r4-->t5 w/ram clutch
Cold air, 1.6 rockers, 21lb injectors, 3" y-pipe, random tech cat, 3" ipipe, flowmaster 80 series 3" in 3" out hand made stainless tips, Lakewood LCA's, Msd 6a, Msd coil, Wonder Bar, 180* stat,
Coming Soon: T/a hood, painted, panhard bar,4thgen front seats, compucam, msd 8.5 wires (accel is CRAP)
"I'd rather run last in a full out race, than to NOT have run at all"
See my car Here!
#3 Forever
See my car Here!
#3 Forever
Car: Firebird
Engine: 3.1 L
Transmission: auto
600 permanent, after new digital EGR, ECM, IAC, Coolant sensor, new wires und spark pluggs, new ignition modular
www.marion-becker-nidda.de
91 Firebird 3.1
Mods
ynomax ultra flow stainless steel -americanracing rims (ar26) rear 15x8 255/60
front 15x7 235/60
www.members.aol.com/tramphorst/pontiacpics
91 Firebird 3.1
Mods
ynomax ultra flow stainless steel -americanracing rims (ar26) rear 15x8 255/60front 15x7 235/60
Yes, I'm not, Thanks 350.
89 RS
STILL Looking For:
89 RS
STILL Looking For:
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
1250-1500
Slayer of the following:
1996 Riced-out Honda Civic (all show and no go!!!!!!)
2000 saturn
198? Ford Crown Vic, (no i don't know why he bothered)
1990 Buick LeSabre 3.8
1986 Camaro 2.8
Newer Ford Explorer
Food that makes me sick: RICE
1991 Camaro RS 3.1 V6 5-speed
1991 Z28 Rims with Firestone Firehawks
dual snorkel intake w/ slashed boxes, 2 K&N's, 180* t-stat
my motto: I CAN'T DRIVE 55
2000 saturn
1986 Camaro 2.8
Newer Ford Explorer
<font face="Verdana, Arial" size="2">Originally posted by Ovrclck350:
Hey Camaro Hunter. I can vouch for IROCZTWENTYGR8, he's not a troll. Ease up there man.</font>
I assume I idle at 750 or so.
I do not know as my tach is not hooked up yet. I have a gauge cluster to install.
Mine idles so smooth after I've fixed ALL vacuum line breaks (EVERY SINGLE LAST ONE OF THEM, SEEK AND YE SHALL FIND THEM!!) and swapped out a bad ICM. I have also cleaned the Idle control sensor in the throttle body, too.
All those things contribute.
BUT
BUT
BUT
Cheapest fix & BEST FREE EFFORT was the vacuum lines! Use 5/16" & 1/4" windshield wiper hose for repairs.
I'll bet if ya check codes, you'll see malfunctions, too.
I eliminated my malfunction codes by repairng vacuum leaks. Saved me over $75 (from buying another MAS sensor!)! Codes went away! Super smooth idle now! Clear computer after you think you solved all the vacuum leaks and check codes again. I think you'll have none!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
BUT
BUT
BUT
Chat Soon,
KED85
Karl
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
My tachometer is there...but it's faulty. It says I idle at about 1400, with a normal operating temp engine..
91 RS 3.1 V-6
91 RS 3.1 V-6
91 RS 3.1 V-6
91 RS 3.1 V-6
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
<font face="Verdana, Arial" size="2">Originally posted by 1991tealRSt-topGuy:
1250-1500
</font>
1250-1500
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!</font>
someone972
Aug 30, 2015 12:52 AM
