Trany question.
Old Oct 1, 2001 | 11:27 AM
BitchinRS's Avatar
Trany question.
Ok, when I'm pooring the coals on and I shift kinda hard I will the trany thump the mont. It's not a clunk just a thump. Is this a sign of a fail trany mont?
I have been trying to avoicd lifting the car and visualy checking, becuase I'm on a semi steep driveway and hate to lift it off all four wheels.
1992 Camaro RS 3.1L 5 speed manule trans.
Thanks!!
Old Oct 1, 2001 | 11:35 AM
Monkie's Avatar
u might have cracked the mount. Or bent it. If it was broken you would know. When you press the gas in 1st or 2nd does the shifter move any?
Old Oct 1, 2001 | 04:07 PM
BitchinRS's Avatar
I haven't paid much attention wether it does or not. I check on my way home tonight. Allthough right it still has a bit off a rough idle that I haven't been able to figure out that makes it shake a bit wether or not I step on the gas, but I will check and give an answer later tonight.
Old Oct 2, 2001 | 12:18 PM
BitchinRS's Avatar
Well in first it moves up some and shakes a little even though it I do a nice smoth start. It also does it in secound, but to a lesser degree. It's almost as if the trany moves up when I press the gas pedel.
I'm not sure if it is normal, but the car has done it ever sence I baught it with about 130,000 miles on it (current milage is 160,000) . It blew the clutch about 4 weeks after baught. So the entire clutch assembly is brand new, becuase it blew up into a million little bits.
ZZ3Astro
Aug 13, 2019 12:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
corey8084
Sep 17, 2015 02:56 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Ian Irvine
Sep 4, 2015 08:08 AM
