dumb Q. but what does it mean to run lean or rich??
Old Oct 8, 2001 | 11:44 AM
87_Camaro's Avatar
the title explains it exactly, what does it mean to run lean or rich?? and what is better to run on? does it mean the air flow? please enlighten me so i dont have tog ive myself head aches trying to figure it out, thanks
P.S. if i have MPFI is it good to run lean or rich?
87 V6 2.8 MPFI Camaro SC
Modded dual snorkle intake "bottoms hacked off", K&N air filters, Crane Cams 8.5mm fire wire, Accel Cap and Rotor, MSDcoil. upcoming mods:
Dynomax CatBack exaust system = VERY SOON
crane cams camp shaft, CC roller rockers, double timing chain
Old Oct 8, 2001 | 12:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
"stoichiometric" air/fuel ratio = 14.7:1.
Running "rich" means there's more fuel in the air/fuel mix. Running lean means there's less fuel. For power, it's better to run a bit lean than rich. For fuel injection, nothing needs to be changed. You can change the fuel presure regulator (on the fuel rail) to be higher or lower. The higher the pressure is the higher the air/fuel ratio.
Rally Smith
Sep 14, 2015 06:59 PM
u r sofa king we tah did
Mar 28, 2002 05:50 PM
AmorgetRS
Feb 12, 2002 12:29 PM
812MANY
Jul 5, 2001 09:57 PM
91-GasGuzlinZ-28
Mar 15, 2001 10:34 PM
