2.8 mpfi engine boring
Old Oct 16, 2001 | 04:50 PM
V6camaroman's Avatar
how much extra hp would i get from boring my 2.8 .030 over? is it worth boring it out or just keeping it stock bore?
Old Oct 16, 2001 | 05:36 PM
87_Camaro's Avatar
well i read somewhere on these forums that boring them 0.40 over would be the equivalent of having a 3.1liter if thaats any help
Old Oct 16, 2001 | 09:59 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you could always do what I will, 3.4 heads, gmpp 3.4 cam, new timing set, etc, etc.
Oh yeah, a turbo might not hurt either
Old Oct 16, 2001 | 10:40 PM
Streetdemon624's Avatar
I thought the 3.1 or the 3.4 was the 2.8 bored or strocked? I don't know.
86 2.8l Camaro, Z28 hood, R134a retrofit system, custom air intake, American Racing Chrome Nugget 15x7 rims, 225/75/R15 phantom tires, Cobra Ultra 2 CB/PA, Sony CDX-L250 cd player, 1.5 " rear lift.
Old Oct 16, 2001 | 11:56 PM
86bird_28v6_5spd_ramair
Guest
Posts: n/a
there all the same egine just each one is a little bigger, best bet is just get a 3.4 from junk yard, rebuild and bore that, its all the same engine so everything on the engine works on any of the 3.
and then ou can take your time, do it right, and still be able too drive your car till its ready, and do an easy 4 hr swap.
http://PCperformance-usa.com/86bird/86bird.html
Old Oct 17, 2001 | 12:05 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Yes the 2.8 is the same block as the 3.1, the 3.1 is stroked. the 3.4 is a different block but shares the same crank, but different cam. The 3.4 cam works in all blocks and it is the better cam. Bore on a 2.8 and 3.1 is 3.5" and can only be done .06 over I Think. Best bet if you have a 2.8 is just to get a 3.4, TALK TO KED85.
Old Oct 17, 2001 | 07:40 AM
Brian K's Avatar
Bore it 40 over, mill the heads, toss in forged pistons and the n100HP of NOS.
Old Oct 17, 2001 | 02:29 PM
Kevin S's Avatar
When a 2.8 is bored .030 you gain 3 ci.You won't really notice anything gains.You do get some wierd looks when someone ask's what you have under the hood and your reply is a bored .030 2.8
The next time you think your perfect,try walking on water!
Old Oct 18, 2001 | 11:41 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah; on our motors, boring is more of a clean-up-the-holes job...
-Tom P (Hot rodded 1986 Firebird 2.8l)
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
