Front Tubular Control Arms???
Old Oct 28, 2001 | 08:43 PM
DeadHero8's Avatar
where can i get front tubular control arms for my six cylinder. does it make a difference if they are made for an 8 or a 6?i havent been able to find them for either
Old Oct 28, 2001 | 09:35 PM
87RS402's Avatar
QwikTrip got his from PA Performance, along with a complete tubular front crossmember. You might look up his profile and send him an email. He could help you out on all the information you need.
Old Oct 29, 2001 | 01:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
All the suspension pieces between V8's and V6's, with the exception of a few factory special optioned parts, are the same. And I can't think of a special-optioned part (i.e. wonderbar, quick ratio steering box, sway bars) that won't bolt up to a V6...
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 29, 2001 | 03:53 PM
BitchinRS's Avatar
I belive the only thing from a V8 that wont work correctly for a V6 is the front springs. they are deigned to hold the extra wieght. other then that it should all be interchangable.
Old Nov 1, 2001 | 01:04 PM
DeadHero8's Avatar
thanx guys, know where i can get all four lowering springs for my sixer?
-Bruce
Old Nov 1, 2001 | 01:47 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
camaro_hunter_d should be able to hook you up.
$150.00 2.8 Auto.
Blown Head Gasket.
turbo has arrived, but put on hold (4 now)
working on dismantling engine, & finding out what parts I need (and Really want)
Old Nov 1, 2001 | 03:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
<font face="Verdana, Arial" size="2">Originally posted by BitchinRS:
I belive the only thing from a V8 that wont work correctly for a V6 is the front springs. they are deigned to hold the extra wieght. other then that it should all be interchangable.</font>
True... I was speaking more along the lines of the design of the suspensions being the same, and yeah, you could put v8 springs on a v6. Of course like you said, it'd be the wrong application for a factory part...
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
