New T-Stat Installed
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I put a New T-Stat in 180 Degree noticed my car was a lil pepier my old tstat somehow got rusted dont know how. But any ways here is a Easy way to install a New Tstat took me 20 Mins and i didnt have to take off the upper penleum
Get a 13MM short Sockert with a Swivel and extension that has a little bit of play in it and set it on the bolt and bam its off. While your at it paint the T-Stat housing make it look nicer then that dingy metel color i painted mine almunium Looks Awsome most shiney thing under my hood.
Car: 1986 Firebird
Engine: 2.8 V6
Do you have a gasket to scrape on yours? I need to pull the TB to make scraping my gasket easier on my hands...
-Tom P (Hot rodded 1986 Firebird 2.8l)
Actuly when i went to peop boys they tried to sell me a gasket sayin thts what i needed but ive done this before and there is no gasket the T stat housing mounts glush onto the manafold. but the T stat has a Rubber Gramunt thing around it like a seal and that goes on the lip of the T-Stat and that is what seales it up. If i confused you just tell me an dill try to explain better i just woke up.
From: First one out of liberty city, burn it to the ground
Any idea when you want the 6a yet?
1972 Chevy Chevelle "Malibu"
Hooker Headers, Flowmaster 40 series mufflers, accel 8.8 wires,Edelbrock performer intake Edelbrock Carb, Torque Thrust "D" wheels
Click here for my Malibu information
In Memory of #3 Dale Earnhardt
My attorney said i should have the check by friday if not call them but the back has a court order to give me the money ASAP
Car: 1986 Firebird
Engine: 2.8 V6
Really! Did this grommet come with the t-stat, or did you have to move it from the old stat to the new? I guess the 3.1 motors' intake manifold is different than the 2.8... when I set my thermostat in the hole in the intake manifold, the edge of the t-stat is right against the edge of the hole... as in, I'd have no room for the grommet.
I heard of some water necks coming with a built-in O-ring... but all I see in catalogs are ones for V8's.
You have to go and match the gasket at pepboys they try to sell me a paper gasket and the first time i did that it leaked all over th place and i took the old groment off thikning the paper would work but it leaked. So i went and had to open bags at pepboys to find a new one. When you take the old Tstat out the Fromet is very dry and brittle and harrd like a rock so its easier just to replace it only costs 99 cents
Car: 1986 Firebird
Engine: 2.8 V6
Thanks, I'll have to check it out. I have to slop a TON of gasket sealer on that paper gasket to keep it from leaking. That makes scraping the old gasket (twice a year!) into a pain in the *** , fast.
Ya the store sold me the gasket the first time i did it and the next day on my way home from school i pulle dup in my driveway with coolant pooling out of it. I dont think GM uses too many gaskets even our exhaust manafolds dont have gasketss its metel to metel.
gixxer92
Sep 1, 2015 04:32 PM
