Roller Rocker Cam
Old Nov 4, 2001 | 04:13 PM
87chicken's Avatar
Roller Rocker Cam
Can i use the same Roller cam from a 5.0 firebird motor, for a 3.4? i konw i can use the 5.0 rockers for a 3.8.. any thoughts?
Old Nov 4, 2001 | 06:33 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
no, use the cam from the ford straight 6 300", just cut it in half
I'll leave it at that, someone else get the kill
$150.00 2.8 Auto.
Blown Head Gasket.
turbo has arrived, but put on hold (4 now)
working on dismantling engine, & finding out what parts I need (and Really want)
Old Nov 4, 2001 | 09:17 PM
87chicken's Avatar
i Ment using the 5.0 GM Roller cam for a 3.4 GM motor... not gm to ford.
Old Nov 4, 2001 | 09:30 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
yeah, you can. just weld two extra cylinders on the engine.
Old Nov 4, 2001 | 09:56 PM
Engine: 5.7 / 7.4
ok, if you want a roller cam for the motor, get one for the 6 not 8. gm does sell this, just get the block from the newer 3.4 cars, fab some mounts, get heads from 93-95 3.4 f-body cars & there you go. nuthin to it.
Old Nov 4, 2001 | 10:05 PM
87chicken's Avatar
Yeah but i was kinda trying to avoid buying them, b/c i FOUND two FREE roller cams for a 5.0 that's why i'm asking, i'm not trying to be an idiot.
Old Nov 4, 2001 | 10:21 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
<font face="Verdana, Arial" size="2">Originally posted by 87chicken:
Yeah but i was kinda trying to avoid buying them, b/c i FOUND two FREE roller cams for a 5.0 that's why i'm asking, i'm not trying to be an idiot.</font>
that was a complete oxy-moronic post
Old Nov 5, 2001 | 09:05 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Okay... Lets review... 5.0... V-8
3.4 V-6....
Cam -------- is this long for a V-8
Cam ------ For a V-6....Hence it will not fit.
If you are only wanting to use the lifters.... then that is a different story...
Old Nov 5, 2001 | 12:18 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The lifters are the same bore? Wow, never thought of that!
Yeah, there'd be four extra lobes on the V8 cam, 2 for each cylinder (intake & exhaust), making it too long. Plus, a used cam might not be the best idea, anyway... for all the work involved, ya might as well put a new camshaft in.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 5, 2001 | 01:29 PM
Engine: 5.7 / 7.4
since you found 2 ffree cams, sell them on e-bay & use the money to buy a cam for your 6.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
