stripped threads
Old Nov 18, 2001 | 10:40 PM
thomasfinley59's Avatar
stripped threads
The flywheel to crankshaft threads on one of the bolt holes stripped. What is the procedure for fixing this. If tapped will I need to get a oversized custom bolt? Desperate for information.
Old Nov 18, 2001 | 10:51 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
The easiest thing to do is to take that bolt that goes into the hole to your automotive store and tell them that you need a Heli-Core set for this built. That way they can match up your thread size. The kit will come with the drill bit and tap that you will need and of course the heli core. Be warn though the kits aren't cheap.
Dale Earnhardt was a scholar of the race track that drove with the spirit of a warrior.
My Camaro: http://home.earthlink.net/~singleton052095
Old Nov 19, 2001 | 10:26 AM
KED85's Avatar
Helicoils are very easy to do.
Drill out, tap & insert new, replace bolt.
Drag part is buying the kit.
Maybe keep asking until you find one to "rent ya" the tool.
I'm looking to rent a coil spring compressor right now. I've got two cars for coil spring jobs to do.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Nov 19, 2001 | 09:41 PM
DeadHero8's Avatar
i dont belive you need coil spring compressors to do them in our cars. i took mine out no problem, granted it might make it easier to put them back in but i ahve heard you dont need them
Old Nov 19, 2001 | 10:29 PM
KED85's Avatar
$10 to rent tool is cheap insurance.
Chat Soon,
KED85
Karl
Old Nov 19, 2001 | 10:33 PM
BitchinRS's Avatar
You don't need the compresor for the rears but you will need them for the fronts. The fronts are at an angle and if they happen to let lose your could be in a world of hurt.
As foor the strip bolt. You can buy what is called a "tap and die" kit. This is better then then the Heli-coil. If you use the coil and end up having to take the olt out again they sometimes come out with the bolt and then you have to put another in again. With the Tap and Die you rethread the hole all together. which I feel is the better route to go.
Linson
Sep 21, 2015 01:08 PM
gta892000
Sep 16, 2015 12:37 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Amillionoh7
Sep 5, 2015 11:44 PM
