BUILT 3.1 RUNNING VERY RICH
Old Oct 8, 2011 | 01:03 PM
sick92rs's Avatar
Car: 92 camaro rs
Engine: built 3.1
Transmission: built 700r4
after $2000 dollar machine shop bill and countless other parts car runs but has fouled out 2 sets of plugs within 50 miles with no power whats so ever seems to have weak spark and i cant figure out why any ideas are very welcome.. please and thank you
Old Oct 8, 2011 | 02:18 PM
project89's Avatar
Re: BUILT 3.1 RUNNING VERY RICH
whats all done to the motor, and for 2000 bucks that better have forged pistons a custom cam and lots of port work
Old Oct 8, 2011 | 08:37 PM
sick92rs's Avatar
Car: 92 camaro rs
Engine: built 3.1
heads cut blocks decked port polished forged pistons bored 60 over blanced rotating assembly machine crank 460 lift cam 1 to 6 rockers pacesetter headers theres more that i cant think of right now lol
Old Oct 8, 2011 | 08:44 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Tuning?
Old Oct 8, 2011 | 09:11 PM
project89's Avatar
Originally Posted by Six_Shooter
Tuning?
need cam specs being a speed density system if the cam dosent pull the same vacum as stock the ecm will add more fuel.also make sure the map sensor is hooked up and the vacum line is also connected. if it isnt the ecm will see no vacum and try to add the same amount of fuel it would at wot
r u using stock injectors?
Old Oct 10, 2011 | 05:15 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Could be weak spark from bad IC, or perhaps you need diff heat range plugs, and running too rich could also cause the problem.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
