installing K+N airfilters
Old Nov 19, 2001 | 05:04 PM
Paky's Avatar
Hello all and Happy Holidays, Ihave a question about installing the K+N airfilter on a 87 2.8 stock camaro,in the box with the filters(it takes two) was a gasket that wouldnt fit on my car. also I installed them with the ridges facing up, is this wrong? seemed the only way they would go in any help would be greatly appricaited, thanks in advance
Rick P.
Old Nov 19, 2001 | 10:41 PM
BitchinRS's Avatar
You have the dual snorkle correct? If you do they should be pointing down. I swaped restrictive coffe can style air intake to the dual snorkle, and when I tried to install the K&N's it gave me a little trouble. I just had to push down a little harder then normal and evrything work fine.
Old Nov 19, 2001 | 10:42 PM
BitchinRS's Avatar
Also which K&N part number are you useing?
Old Nov 20, 2001 | 06:41 AM
WaynesRS's Avatar
hmmm.I have a 88 2.8 with K&Ns mine just dropped right in there , fit like a gloove .Maybe the wrong filters ? Not to sound sarcastic or smart . But maybe you put them in their wrong .Read the instructions on the box ..Goodluck man ....Wayne
Old Nov 20, 2001 | 09:05 AM
87_Camaro's Avatar
I have an 87 2.8 camaro and I have K&N's in my dua snorkle, they droped right in for me "although I have the boxes gutted" wich could be the reason why they didn't give me any, if I were you I would just gut the boxes and drop the K&N's in, you will receive much better air flow than before.
87 V6 2.8 MPFI Camaro SC
Modded dual snorkle intake "bottoms hacked off", K&N air filters, Crane Cams 8.5mm fire wire, Accel Cap and Rotor, MSDcoil. upcoming mods:
Dynomax CatBack exaust system = VERY SOON
compu cams cam shaft, CC roller rockers, double timing chain
first kill ever = 80's FireBird SE Others: 1998 Ford Conture
Old Nov 20, 2001 | 05:05 PM
Paky's Avatar
First thanks for responding, I do have then in they fit fine but only wit the ridgs facing up, are all you saying the flat part faces up in your cars? I see what you mean about the bottom getting in the way the water baffels, but do you get water in there without the bottoms on? thanks again
Old Nov 20, 2001 | 06:02 PM
WaynesRS's Avatar
The ridges are suppose to face down , the top flat .Sounds like you dont have the right filters or defective ones ..Dont know if thats possible ...but ...Wayne
Old Nov 20, 2001 | 06:04 PM
WaynesRS's Avatar
Mine , and I think most , unless you have a conical set-up , the black lining on the outside fits plush into the edges of the boxes .Sounds like you have the wrong filters if you can get them in there upside down ...Because mine wont fit in their with the ridges up .Wayne
Old Nov 20, 2001 | 07:13 PM
87_Camaro's Avatar
same here I tried it also and it wont fit like that, you have the wrong ones, here is the model no. of the K&N's you need:
33-2008
if the model no. for the K&N's you have isn't the one I just posted, you have the wrong ones, if it is then you have defective ones or someone put the wrong ones in the box. I am positive that is the model no. of the K&N's you need because I just got them off my box
Old Nov 20, 2001 | 08:02 PM
WaynesRS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Paky:
</font>
poor fella , thinks he can't install a simple K&N and some jack a$$ at the parts store gave him the wrong ones !
Don't worry the right one fits like a gloove Wayne
Old Nov 21, 2001 | 03:13 PM
BitchinRS's Avatar
As far as whether or the water gets in, no. The water from the road or from a good rain doesn't get in. Just don't take the car for a swim and you'll be ok.
I hit a flooded par tof the street last night. but fortunetly I was going verry slow (15MPH). Scared the hell out of me becuase I couldn't see it, but no watter got in there.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
