V6 Throttle Body MM size?
Old Nov 20, 2001 | 11:20 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey guys,
How big is the V6 throttle body? (in millimeters). I'm guessing the Single V6 hole is slightly bigger than the holes in the V8.
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters, Summit 1.5 roller rockers, World Products Sportsman II
2.02/1.60 heads, Edelbrock TPI Intake, Cloyes Double Roller, timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs gauge, A/F ratio gauge.
http://www.joesperformance.com
-- Joe
Old Nov 20, 2001 | 02:16 PM
BitchinRS's Avatar
i think it's some were around 50MM. I saw an after market with a 3MM large bore and it was 53MM.
Old Nov 20, 2001 | 03:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
How is that measured, anyway? The TB opening is an oval... are we talking width? height?
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 20, 2001 | 03:57 PM
BitchinRS's Avatar
To tell you the truth, I have no clue. I'm gonna try to dig up some specs on it, and I will let you know what i find.
Old Nov 20, 2001 | 04:54 PM
KED85's Avatar
When GM modified a Cavalier Pace Car for the Indy races (in the 80's), they used a STOCK throttle body from a Corvette.
Adapted that to a modified air box to fit the runners for the 60* V-6.
Give ya any ideas?
Since I moved, I unearthed tons of old car mags I've had. I misplaced that issue with the engine specs.
But, it did say that they used that "custom" set up for the upper intake.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Nov 20, 2001 | 05:43 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey,
Just came back from the junkyard (again) this time with a micrometer.
The throttle plate (what matters) is round.
It measures 54MM as far as I can tell (without of course taking the plate out, but I think I'm pretty darn accurate).
I'm gonna take two apart in the morning (those little T6 screws suck) and get an exact measurement. Either way, it appears
to be 52MM or larger.
My buddy is a machinest. He can bore my holes
for me for free, but asside from that, any good engine shop should be able to do them
for no more than 10-20.00 a hole. So think about it guys, for under 60.00 for everything
(assuming your junkyard doesnt rob you for the 2.8 throttle bodies), and a couple hours of time you can have a 52-54MM throttle body.
I'll keep everyone updated on my progress.
-- Joe
-- Joe
Old Nov 20, 2001 | 05:46 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
My guess is this will get moved to the TPI board eventually, but I do appreciate the responses meanwhile.
-- Joe
Old Nov 20, 2001 | 06:08 PM
WaynesRS's Avatar
How big are the 3.4 ones ?
How big are the 3.8 ones ?
Would this work on our 2.8s ?
Would a vette one work on our cars ?
If so how much do you think one would go for in the junkyard , how hard is it to put on ? Is this enough questions ? Wayne
Old Nov 20, 2001 | 07:07 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Not sure how big any of those are.
Vette ones are 48MM. remember, 8 cyl cars have two holes. You V6 guys have 1 hole. So you'd need to find something a little larger.
I bet you a 58MM plate would work pissah on a V6, with an adjustable regulator.
-- Joe
-- Joe
Old Nov 20, 2001 | 08:33 PM
WaynesRS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by anesthes:
-- Joe
</font>
Pissah ? huh ? ...please define
thanx , Wayne
Old Nov 21, 2001 | 03:44 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wow, (laughs), I feel like a dumbass! So the plate's round, eh? You'd think I would've noticed that by now!
Old Nov 25, 2001 | 10:11 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Hey guys,
-- Joe
</font>
over at www.firebirdv6.com, the specs for the 3.4v6 TB is 50mm.
Old Nov 25, 2001 | 02:06 PM
mrr23's Avatar
Engine: 360 HSR
<font face="Verdana, Arial" size="2">Originally posted by WaynesRS:
</font>
the 3.8 are 65mm according to www.firebirdv6.com
Old Nov 25, 2001 | 02:39 PM
Xenodrgn's Avatar
Did we ever get an exact measurement?
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Nov 25, 2001 | 02:55 PM
KED85's Avatar
THE ONLY PROBLEM IS THAT you MUST USE the TB application for your car.
OR ELSE NOT THING LINES US (cables, etc)
When I did my 3.4 swap, I REALLY WANTED TO KEEP THAT 3.4 set-up.
But, NO WAY, was it EVER gonna work with my 1985 cable & such for gas pedals.
If ya gonna go custom, everything must be Custom.
Increase your air flow into the engine for better performance gain.
Chat Soon,
KED85
Karl
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
