DUAL OIL FILTER RELOCATION KITS
Old Nov 22, 2001 | 05:33 PM
86bird_28v6_5spd_ramair
Guest
Posts: n/a
anyone done this yet???
anyone used the 50 dollar kit at jcwhitney???
will the stock oil pump have no problems with one???
will my car have just as much oil psi, having dual filters and a few feet of hose???
how much hose is too much, like what about relocating them to in front of the raditor in the air flow????
i bet the extra cooling would be nice.
http://PCperformance-usa.com/86bird/86bird.html
Old Nov 22, 2001 | 07:28 PM
Camaro_hunter_d's Avatar
Go to Summit. cheaper and name brand. yes they have them for the 60* motor. I want to say it was 35-40 last I called about it.
Old Nov 23, 2001 | 11:12 AM
KED85's Avatar
And you buy more places for your oil to leak from!
Spend your money elsewhere, honest.
This item is not necessary for our 3rd Gen cars.
"ALL OUT RACE CARS" with headers exiting from that area under the engine/chassis, sure. Proper solution.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Nov 23, 2001 | 10:37 PM
DeadHero8's Avatar
hey do you have that part number for summit? i am deffinatly gonna want this mod.
-Bruce
Old Nov 24, 2001 | 12:01 AM
WaynesRS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by KED85:
</font>
Not trying to tell you what to do . But If I were you , Id really listen to Karl . He really knows his stuff .Wayne p.s. I also agree with Karl , your buying more places to leak oil from .
Old Nov 24, 2001 | 10:10 AM
KED85's Avatar
NOR AM I TRYING TO BE A KNOW IT ALL.
My Brothers 2nd 1961 Corvette had that set up. All it did was leak.
It's just not the best nor wisest project to put your street car effort into.
What is the reason for using a remote oil set up on your car?
Do you know how much fun it is to wipe down the fenders after you remove the oil filter and all that oil spills over the innner fenders, ground, sprays onto the eingine, etc?
Chat Soon,
KED85
Karl
Old Nov 24, 2001 | 07:27 PM
Guest
Posts: n/a
i dont think i would even worry about leaks myself, but if that is so then a stock pump must have plenty of pressure.
if it can make oil leak past a good hose clamp. water system run more pressure than oil right???
i just want to make sure im not gonna screw up my oil pump.
if pressure is no problem, i would run them up front like an oil cooler.
Old Nov 25, 2001 | 02:32 PM
Xenodrgn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 86bird_28v6_5spd_ramair:
</font>
Why not just run an oil cooler then??? Seriously dude, two oil filters is money better spent elsewhere.
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Nov 30, 2001 | 03:43 AM
jijiandfarmgang's Avatar
Hey,
Sounds like a good idea to me, Im gonna get one soon. My freind has that setup on his truck. I think you have problems elswhere if you get a leak from two hoses. Who would be against better oil filtration?
Old Nov 30, 2001 | 07:42 AM
82camaro's Avatar
Car: 82 camaro SC
You won't get better oil filtration--just increase capacity to hold the stuff found in the oil. If you change the oil as often as you should and use a good filter, you won't get any gain from having 2 filters. Putting the filters out in the air stream, you will risk busting a filter open from a rock or other object. The cooling effect will be minimal at best(use an oil cooler for that). Convenience, sure it's easy to change the filter, but you still have to get under the car and pull the oil plug--so why not yank the filter while you are down there. If you want this mod, go for it. But I'm sure some of us would like to know why.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 30, 2001 | 10:06 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I also agree with Karl (& everyone else), the dual oil filter isn't worth the cost. Make sure you're using a PF52-equivilant (long) filter, and not the '86-spec'd-by-auto-parts-stores PF47-equivilant filter, change your oil frequently, and you're good to go.
It's usually an off-road mod for trucks, since trucks are usually in dusty situations (off-roading). But for the street, I wouldn't bother. There's got to be something else worth $50- If you want to add some splash to the engine compartment, get the Russell braided dress-up hose sleeves from Summit. (I have 'em, they're fun!)
-Tom P (Hot rodded 1986 Firebird 2.8l)
maroe624
Apr 16, 2017 08:29 AM
Derick15
Sep 17, 2016 05:28 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
