engine stalls and speedo won't work...
Old Dec 8, 2001 | 06:41 PM
dailydriver's Avatar
My brother's 1990 RS with a 3.1 and auto tranny is having some problems. The speedometer quit working. Where is the speedometer "sensor or module"? Also, the engine stalls (misses) when taking-off or if it's idling and you just barely press the gas. We have replaced the fuel filter, distributor cap and rotor button. Could it be the catalytic converter?
Old Dec 9, 2001 | 09:40 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Well, the idling problem could be a few problems.
1) Vacuum leaks.... noted to make your car run bad.
2) Misc. Sensors, you will have to pull codes from the ECM for this, there is a tech article on the main page
3) If the exhaust is not tight, leaking it can cause some missin
4) Timing is off.
As for the speedometer, test the wire running from the speeometer first, there might be a break in one of them, if not go to a junk yard and pick up a new speed module for $5-10.
Old Dec 10, 2001 | 10:04 PM
I have tried to pull the codes but can't. I ran a jumper from the top two right "slots" as per the tech article but never could get the codes. I did the same on my 1986 Camaro and it worked. Could there be a problem with the ECM?
Old Dec 12, 2001 | 01:37 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
I think your dam close with the ECM
Horst
www.marion-becker-nidda.de
91 Firebird 3.1
Modsynomax ultra flow stainless steel -americanracing rims (ar26) rear 15x8 255/60
front 15x7 235/60
www.members.aol.com/tramphorst/pontiacpics
Old Dec 19, 2001 | 01:57 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Check the bulkhead connection. when mine rotted away i suffered from rough idle (had to keep giving it gas a a stop) and when I put the key into the "on" position to pull the codes the check engine light didn't come on!!
Jorlain
Aug 24, 2022 05:11 PM
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
beachrodder
Aug 7, 2015 04:27 PM
