At what MPH and RPM does your car shift 1,2,3,4........
Old Dec 6, 2001 | 08:28 PM
86BIRD-MY FIRST CAR's Avatar
just wonnna see how every one else car shifts....
86 firebird 2.8
K&N replacement filter
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
Old Dec 6, 2001 | 09:45 PM
WaynesRS's Avatar
I dont know , but I'll look tomorrow when I drive it and tell ya .
Wayne
Old Dec 6, 2001 | 10:03 PM
BitchinRS's Avatar
Depends on how I am driving. If it's just around town and I don't want to chew a lot of gas I go by the shift light. If I'm kicking it in the *** I shift a about 3K for 1st. and secound, It doesn't seem to pull much after that. 3rd I shift 3500, and forth seems to pull hard all way to 5K. I haven't taken forth passed the 5K mark becuase I'm a big chiken and don't want to red line it.
Old Dec 6, 2001 | 10:13 PM
Monkie's Avatar
1st:15mph
2nd:35mph
3rd:70mph
4th:93mph
5th:who knows
Old Dec 6, 2001 | 11:25 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
At what?? WOT?
Old Dec 7, 2001 | 12:45 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
at WOT,
the car shifts outta first gear at about 6k flat, gives about 40mph, second gear moves until 75, when i let the car shift itself, it will do so at about 5100rpm, never held it all the way through third, could only pull about 4900rpm though, which should have been about 115mph, just about where the speed limit was...plus there was antoher gear and a lot of RPM to go.
Old Dec 7, 2001 | 10:33 AM
89BlackBirdKid's Avatar
My first goes to about 20 then my second gear goes to about 45 or 50 3rd redlines at like hmm like 75 and after that I'm going for topspeed.
Josh
1989 Firebird
Working the 2.8 to 3.4 swap with a 5 speed.
Kills: 2000 Silverado V6, 1995 v6 mustang, 1994 rodeo v6, 2001 Ford Sport trac, 1992 honda prelude riced out
Losses: 89 GTA, 95 Z28, 90 Camaro 305 TBI with mods
Old Dec 7, 2001 | 12:13 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I've got an auto, and my tach is bad..but I'll shift around using 1>2>Drive sometimes, and I can guesstimate pretty close at what RPMs I'm coming up on by the feel.. I give it a long time before shifting out of 2nd, I let it ride up to around 4800. I dunno about you guys, but I pull REALLY sluggish in low RPM's in 2nd gear but the car screams when it goes into the real high RPM's. It's high-rev happy I suppose. This is true for first gear too...it gets a real hard pull around 3500-4000. Running bone stock too except the air filter & spark plug wires..as if those really count anyways. ;p
Old Dec 7, 2001 | 11:16 PM
For me it:
1st-15mph,1500RPM
2nd-20mph,2400RPM
3rd-45mph,2900RPM
4th-70mph,3100RPM
is my times good,off? if off how can i adjust this
86 firebird 2.8
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
Old Dec 8, 2001 | 05:43 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
just for shlts and giggles I will throw the shift mph for my rx7 in here
this is with 4.10 rear end gear and 205/60/15 tires
shift at around 7600-9000 depending on how I feel
but with a shift point of 7600 rpms the mph are listed as
1st>2nd at 36
2nd>3rd at 65
3rd>4th at 94
4th>5th at 125
these are kind a little rought so you might have to give -/+4mph or so
but kinda a shock for having 4.10 rear end. what gear is it you guys are running
cause from what I see so far it looks like even though I have a really low rear end gear I shift at about the same time you guys do
you think I should put a 4.30 rear or a 4.88?
imports are cool - ricers suck
ICQ 4116192
AIM RXspeed87
Got rotary?
running a turbo motor with 12psi.
full dual 3 1/2" pipes comming off the turbo
FMIC,CAI, ram air, e-fan,
soon to have ported intake,TB, and motor
best time 12.5 on G-tech
prev best time 14.8
hoping for 11.x soon :-)
but I broke another driveshaft...
and still running full street trim :-)
Old Dec 9, 2001 | 04:12 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
just found the owners manual & an rpo sheet in the bird, here's what it says for shifting:
acceleration
1-2 15mph
2-3 25mph
3-4 45mph
4-5 50mph
cruise
2-3 24-25mph
3-4 32-45mph
4-5 45-50mph
$150.00 2.8 Auto.
short block now
turbo eventually, 3.4 may be in the future
76 Bonnie: 400/400 CIA/Ram Air w/ metal clothes dryer ducting
"And you thought a Caprice was big"
Giving the enemy the opportunity to die for their country
Old Dec 14, 2001 | 12:59 AM
SlowCamaro88SC's Avatar
outta first @ 5100 (evil tranny issues, I won't even go into it)
outta second @ 6000 ish(sometimes I hit the rev limiter) @ about 70-75
outta third @ 5800 ish @ about 115
then I run into a brick wall acceleration wise and can't go any faster.
'88 Camaro - For Sale, $1900
3200 Stall TC, B&M Transkit, Flowmaster CB, CAI
Z/28 Hood, Z/28 Grille, Foglamps, IROC Wheels
White Face Gauges, DRLs
'94 B4U Grand Prix SE
Charcoal Crosslace Wheels, DRLs, CAI
Clear Tails, De-Badged, A\M Exhaust
TreDeClaw
Aug 14, 2015 06:58 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
dhonda200
Aug 11, 2015 11:50 PM
hokis
Aug 9, 2015 03:57 PM
gwade12
Aug 8, 2015 08:17 AM
