looking at switching air intakes
Old Nov 14, 2011 | 02:40 PM
emerald91fbird's Avatar
Car: 1991 firebird
Engine: 3.1 l v6 mpi
Transmission: auto
i found a air intake but im not sure about it and im concerned about the senor that goes into my air box now .
I have a 91 Fbird with a 3.1v6 bone stock
this is what im looking into
http://www.ebay.com/itm/PONTIAC-FIRE...ht_3540wt_1139
what do i do with senor? and should i buy this and put it in?
Old Nov 14, 2011 | 04:21 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: looking at switching air intakes
you can use a air intake sensor from a lt1 ac delco 213-243 and gm grommet 24504388 just drill a hole in the intake pipe.
Old Nov 14, 2011 | 04:57 PM
Car: 1991 firebird
Transmission: auto
will doing that make it CARB compliant?
Old Nov 14, 2011 | 05:01 PM
Engine: Lb9
Transmission: M20
sorry I don't live in california !!
Old Nov 14, 2011 | 05:18 PM
Car: 1991 firebird
Transmission: auto
nor do i , i live in NJ i just dont want to mess up my emssions
Old Nov 14, 2011 | 05:25 PM
Engine: Lb9
Transmission: M20
if the do a visial inspection there and it fails keep the old parts just for emission testing. this setup will not make your car fail emissions out the tail pipe.
Old Nov 15, 2011 | 01:26 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
CARB is California. NJ may have something similar. It would almost certainly fail in CA but you'd have to ask locally. What comes out of the tail pipe is irrelevant to the visual inspection.
Old Nov 15, 2011 | 06:25 AM
ex-x-fire's Avatar
Put the stock stuff on for testing, then swap over after. It should take that long.
Old Nov 15, 2011 | 10:54 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
$54 for that thing! Unless you like the r*cer styiling of it, just remove the metal can around your filter now and use a K&N, thats what I did. It'll have no less effect, you'll have a quality air filter, and you're engine bay wont look like that of a highschoolers Honda.
Old Nov 16, 2011 | 04:17 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I see no reason it would fail emissions, unless there is a law requiring the engine to be completely unmodified out there, out here there are 3 forms of emissions testing, tail pipe, and obd II/gas cap, an aftermarket air intake would fail none of these as long as the sensor is still present and operational(and while ideal, it actually does not need to be in the intake pipe, all it is is an air temp sensor, ambient sample will work just fine, but having it actually IN the intake tract is ideal/preferable), so unless california is just that retarded it won't give you any problems passing an emissions test.
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
