V8 &V6FuelPump. What's the Difference?
Car: 91 Firebird
Engine: V6 3.1 191 cid
Transmission: Typical! 700r4
Axle/Gears: 3.45 BorgWarner 9bolt posi
I am in need of a fuel pump..But the man i have putting it in doesnt like anything but AC Delco..
SO Since the fuel pump for the V8 F.I is 80 bux .And the one for the V6 is 129. I want to know what it matters?
Why couldn't i put it in my V6 and not have any problems.?
Yeah they're both good deals but really what would the real end all effect of this application turn out to be if i did it this way?
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: V8 &V6FuelPump. What's the Difference?
Are you looking at the one for the tpi or tbi?
The difference is in pressure
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
As long as its for MPFI the v8 will be fine, it will just flow more than needed, but hey if its cheaper, why not-won't hurt anything by flowing more than needed.
the v6 and v8 mpfi/tpi pumps are actually the same pump,
i would say i can give u a link to corvette zr-1 pumps for 20bucks shipped but u would need a retune to run one, they flow more volume and the stock return line wont be able to keep up thus raising ur base fuel presure. a single zr-1 pump on my twin turbo iroc is enough to push my base fuel presure to 50psi at idle with the regulator unhooked.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by project89
i would say i can give u a link to corvette zr-1 pumps for 20bucks shipped but u would need a retune to run one...
Car: 91 Firebird
Straight and simple.
It wont affect the performance of the car. There'll just be more pressure pushing the fuel around. EXCELLENT!
Car: 91 Firebird
I think i got it. When i get a corvette that'll change the story. ..Thanks
Car: 91 Firebird
The AC Delco pump cost too much to be farting around with nonsense that isnt going to make any issues.
One or two more Pounds of compression p.s.i...I wouldnt think it would throw the ECM off either as this ECM is the same one used for the v8 as well. from what i understand.Thanks for the reply.
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
the aftermarket V6 and V8 pumps are identical. The price difference is due to simple marketing.
the FPR controls fuel pressure, the pump is responsible for fuel volume.
Numbah-1
Sep 12, 2015 08:57 PM
