My 3.1 now sounds like a tractor
Old Dec 14, 2011 | 12:05 PM
drewfunk's Avatar
On the way to work this morning i noticed my Camaro started running a bit strange, but on the freeway i couldnt really notice. Once i got into town and pulled over it was terrible, the engine sounds like a diesel tractor, loud and clankly. It smelled hot but the temp gauge was still reading low. The car now has very little power. And ideas as to what happened? I'm at work and cant trouble shoot it at the moment.
I just put $700 into it to get it running great, and i have been commuting 80 miles a day for a couple weeks now trouble free.
Old Dec 14, 2011 | 12:10 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: My 3.1 now sounds like a tractor
check engine light on? deffinatly sounds like a huge timing change. exhaust smell differant too? and what was the $700 used for (parts?)
Old Dec 14, 2011 | 12:21 PM
drewfunk's Avatar
No check engine light. Sometimes it comes on because of an egr vacuum hose leak but that's it.
700 went into injectors, pcm, temp sensor, plugs, wires, general tune up, labor...
It does sound like timing being wayyy off, but i dont see why that would of happened so suddenly.
Old Dec 14, 2011 | 12:25 PM
Engine: 383 hsr
it can happen suddenly if electronic spark timing circuit is disturbed with an open. and you shouldnt have any vac lines going to your egr valve. the 3.1's have a digital valve. and even that can cause some drivability issues like ur stating.
Old Dec 14, 2011 | 12:34 PM
drewfunk's Avatar
Ah yes, you are right. I had looked up why my SES was throwing an EGR code when i decelerate, and some people said it was because of a vacuum leak. But i guess that was for the older 2.8s? I did replace the EGR gasket as part of the process to get the thing running a few weeks ago and it made a big difference, and its been running great even though it still throws an EGR code.
I will check the timing on my lunch break haha.
Old Dec 14, 2011 | 12:44 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Sure your exhaust hasn't come loose somewhere?
Old Dec 14, 2011 | 12:47 PM
drewfunk's Avatar
I initially thought that it was an exhaust leak, but i dont think that would explain the loud clanking and loss of power.
Old Dec 14, 2011 | 06:52 PM
drewfunk's Avatar
Looks like it was worse than i thought...
Car leaked out all the oil! Looks like it leaked out the broken oil sensor on/near the oil filter. So the clanking must have been the lifters and such not getting oil. What are my chances of the engine not being toast? It was only a few miles, and it still starts and runs fine besides the pinging noise.
Old Dec 14, 2011 | 07:20 PM
Lively13's Avatar
Car: 1982 Camaro Z28
throw some oil in and dont start her again. Im in the process of replacing my lifters and cam because of oil. So what ever you do, do not start without oil again.
Once you put in some oil theres a slight chance you didnt hurt anything like i did, and she may be good to go. Its costing me $650 for new lifters, cam, and labor.
Old Dec 14, 2011 | 10:32 PM
drewfunk's Avatar
There is oil covering the whole bottom of the engine, looks like i may have blown a seal. I'm hoping i dont find any metal shavings in the oil filter tomorrow....
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
