V6 is on it's last legs.
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
The ole 2.8 is starting to give out on me. She started to knock a little last night, but today, it's doing it all the time. Not really sure if I want to just put a 3.4 in, or do I wanna go carb 350 or 305. She's been good to me, going to treat her well from now on.
Transmission: 5-speed/T-5
Re: V6 is on it's last legs.
Why would it have to be a carbed 305 or 350?
I would go 3.4 or better yet 3.4/3400/3500 hybrid.
Car: 1989 Camaro RS
Engine: LH6
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
A 3.4 should be very quick and easy.
Looks like you just want a quick engine replace and back on your way. Call around the local engine places and see what they have in stock but for a quick job I would probably look for a 3.4
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Yeah a 3.4 is a good bet and you can use your old tranny too
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
If I were needing to do something quick I would go with the 3.4. I myself was planning to drop a 3.4 in my 88 but since I'm about to get my fiero on the road the camaro is probably going to go to the dark side
but it'll be a while before that happens since I'll be moving into a place with a garage and plenty of room and time to work on it without worrying about having to cover everything up when it's about to pour
the only way id go 350 over 3.4 is if u can get a good running 350 cheap,i wouldnt waste my time at all with a 305, but a 3.4 swap will still be the cheapest option
Car: 1989 Camaro RS
Engine: LH6
It would get a 3.4, but I want my cam and 1.6 roller rockers on the 3.4. But, I'm going to pull my belt off to make sure it's not a pulley making the noise.
Car: 1989 Camaro RS
Engine: LH6
Seems like a pulle ywill be the cause of the sound. It hasn't knocked, or made a knocking sound since I drove it to work. Going to do some investigation when I get home from work.
Mrbanados
Theoretical and Street Racing
Dec 22, 2013 12:28 PM
