ECM Compatibility
Old Apr 7, 2012 | 07:35 PM
Hard Driver's Avatar
ECM Compatibility
I have a 3.4 gm crate engine in my first gen. S blazer and would like to install a compatible / tuneable ecm. I have the f body exhaust manifolds[each has an O2 sensor]but still have the S intake manifold with larger 4.3 tbi,still have the distributor not dis. Will the ecm out of a 93-95 f body work with this combo ? I relize this isn't an S truck forum but you guys have given me good info before.Thanks.
Old Apr 7, 2012 | 08:41 PM
ex-x-fire's Avatar
Re: ECM Compatibility
The f body ecm will run it fine as long as you uses the 3.4 efi from the f body.
Do you want to use the tbi on the 3.4? If so then find a 2.8l tbi distributor.
Old Apr 7, 2012 | 09:09 PM
Thanks,I'm already using the 2.8 distributor,just trying to keep the 4.3 tbi which was an upgrade over stock and a easy install.I do have a 3.4 intake and dis coils but didn't want to install them unless I had too.
Old Apr 7, 2012 | 10:58 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
There are a number of ECMs that will work.
One of the most popular lately for TBI application (in any vehicle) is the 16197427, found in the '93 to '95 full size GM trucks. 8192 baud datalogging rate, lots of variables that can be tuned for just about any situation, can run an electronic transmission, and with some modifications can be used in an MPFI application as well.
Look in the DIY_PROM forum for more info, as well as www.gearhead-efi.com.
Since this is a non F-Body discussion, I am required to lock it..
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
